nissky,
If your willing to lend me your car for a session I can make sure that your rears don't make it home if you like!!! (Jokes)
Will be good to have you along... another member of Team Track Day... Welcome.
Jamezilla,
Will be also good to have you out there... make sure that you bring some long gear and $20 so that you can go back down to Melb and brag about how you have been round EC in a skyline... you don't have to tell them it wasn't yours and you weren't driving!
Will update the thread as soon as I look at my bank balance, visit the forums, and your money has arrived people that have just deposited.
Dan.
  • Replies 184
Silver,,,it's a bit hard to explain but yes slotcars do have brakes,,,It's all about your motor's torque and braking only comes into effect when you get right off the throttle,,,,Ha Ha I'll be doing a lot of that on Thursday.
Dan,,,any chance we can get them to cut 8 slots in the track,,,,.
But seriously,,,,what time should I get there and if it rains (Please NO) should I use my street tyres. Duncan HELP!!!!!.
Neil.
7:30am - Arrive early so u can choose your garage and get yourself setup (remove any loose items, change tyres/brakes, etc, etc).
8:00am - Marshalls will check over your car (well walk past and look at it pretty much).
8:30am - Drivers briefing (everybody must attend) and that takes about 15-20mins.
9:00am - First cars will be on the track (group 1 - ie most experienced/fastest).
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
