this intake pipe definately fits a standard turbo and standard afm or a Z32 afm as most of you are aware they are exactly the same size.
The plumb back pipe has to be modified a little bit, as the nozel on the intake pipe is in a slightly different position, but its easy done.
and also you just have to run a blow by hose from your left tappet cover to the nozel shown in my second pic
piece of piss, and looks tidier and no need to worry about the rubber hose suckin in, and a nice induction noise
Hey every im new to this site so i dont no wat im doin :laugh: jus wana say hey n introduce my self... tryin 2 make sum frnds on here so jus n e 1 msg me or n e thin 2 introduce urself :(
thankx heeps xo
i didnt end up getting pics connected up unfortunately. If i did they would of been the first pics up, cause it would of shown how tidy it looks
and how easy it is to install.
Its more time consuming getting the stupid rubber intake off
for this apexi intake pipe that comes with both silicon hoses , lowest i will go is 150 including postage at the moment, as i have interested ppl from other sites.
this still for sale. what area of brisbane you in? also what other parts you got for sale at the moment - i saw you had a dump for sale not long ago too right?
still have the dump , turbo, oil line and a standard manifold all to go,
(turbo is on ebay)
the intake pipe has gone unfortunately, but the guy hasnt replied back in two days, after being sold, so see what happens
let us knw if ya interested in the other parts
yeah i am in brisbane westside.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
