Due to upgrading to a Autronic i am selling my D Jetro power fc, including 3 bar map sensors and a year old handset. The system is in very good working order and also comes with a brand new HKS Twin power module with patch loom and a blitz dual sbc boost controller this boost controller is currently holding 30psi with no fluctuations and is capable of holding 40psi. System is currently on a 727hp setup and is only being sold to upgrade as i am modifying further. Am selling as a complete setup and want $2300 If i have no offers i may consider seperating
Cost to replace this whole setup is well over $3500
PM me for details and pics or alternately ring me on 0422214621
SHOTUGUN POWER FC D JETRO
well if you diside to seperate the gear i am buying the Power Fc D Jetro of you
Thanks Alex :D
Edited by evlgtr
Computer and handset sold
Hks twin power still for sale, genuine offers accepted please this is a Aus spec one with warranty and brand new, do not try and offer ridiculous amounts like one person
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
