  • Replies 81
Posted Images
do u have to standard cooler pipe that goes from the top of the turbo the standard cooler?
if so i'll give ya $20 for it,
let me know,
cheers
Brad
0421841803
am located in the eastern suburbs n would be happy to pick it up.
No turbo available, came with a big aftermarket one which im using myself.
The steering wheel in there has been ripped a fair bit, not worth selling. no airbag anyway.
I have the rear bar, and a rear left taillight. except theres a small hole in the indicator lense as shown in the pics. the rear intrusion bar seems to be stuck to the car with no more nails from the tow bar fitting, so i'm having trouble removing that. and i have a rear bootlid, it's white with a series one spoiler, you can have that for $50. They will all fit a series 2.
no standard cooler piping sorry.
all pm's replied to!!
ALL SUSPENSION COMPONENTS NOW REMOVED AND READY TO BE SOLD!!
series 1 front grille.
yeah i've got the space saver and jack, (i'll have to look for the space saver bolt) call on 0423 366 118 to organise a time to pickup. i'll be going away for the weekend tonight though.
i've got the rear shocks still, the dust boots are torn as usual, but in pretty good nick, no leaks. $30 each. (no springs left)
Hey bud im after all the plastic inner guards for the fronts and condensor for the s1 if ya still got the car let alone the parts! thanks champ.
P.s where you exactly located as im in rosebud near portsea.
i have the air con condensor only, no inner guards sorry. i'll do it for $50. located in epping. call on 0423 366 118 or pm if you want to arrange pickup.
Need this stuff gone guys!!
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
