hi all
i got R34 GTT. the headlight is faily clean but i see the yellowy dirty on inside and outside of headlight...
i want it to clean as crystal...... i clean the outside with plastic compound... but still see the yellowysy dirty colour... may be its from inside...
does anyone cleaned the headlight for R34 GTT or know how to do it?
cheers guys!!!
paul
https://www.sau.com.au/forums/topic/168855-headlight-cleaning/
hi all
cheers guys!!!
paul
i have the same problem with my r33 gtst i asked around for some one to clean it and they wanted $100 bucks to clean each headlight i told him to take a jump.
i also asked autobarn and they suggested some headlight cleaner for about $20 didnt really see a result.
You can use Brasso to polish, then finish with meguires plasticX.
Although if the problem is IN the plastic and not on the surface of either inside or outside and its faded to a yellow, then there's nothing you can do.
Polishing merely just removes the majority of the hazyness and the scratches that cause hazyness and makes it alot clearer.
It's kinda like glass thats made with tint inside it as part of glass. Rub all you want but its still gonna be there.
If your really concerned then buy new lights :dry:
I use meguirs (sp) cut and polish... worked a treat :)
if you want ot clean the inside, you have to take thel lights out, open them up (oven preheat to 200, turn OFF, 15 mins in, pry apart) then put them back together with some sikaflex...
yeh thats why i use polish/wax it keeps them clean for a while, i mean the dirt or stains if u like, dont stick to the surface, because the wax and polish doesnt allow it... i havent had to clean my headlights for over 3 months...
Yes the brand is mothers, Product plastic cleaner, ive been told the use it to remove light scratches from glass as well. super cheap sell it :D
Covered b4, search button is your friend. Well coz im nice here's the direct link. http://www.skylinesaustralia.com/forums/in...showtopic=16255
Get some kerosene or turps and pour some into the light and shake around then tip out n let evaporate. Doing this is also best way to get an moisture stuck in there out. But if there is moisture in there u may a crack somewhere!
Sounds harsh but seriously this works...try it on some other clear plastic if you dont believe me.
- Wet some 2000 grit wet&dry sand paper and evenly sand up the surface of the headlight
- Clean it off and dry it completely.
- At this point you wil hate me because your light will be all faded and look like shit
- Whip out some standard automotive cut and polish and work it over the headlight
It should come up crystal clear.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
