I went the tuner today as I am about to get a tune on the R33
Mods will be enough to get to around 230-240rwkw.
At the moment I am running the new GCG 450hp turbs with the old stock turbo tune.
If you ease into the throttle in say 4th gear at 3000rpm then back off slowly you get a jerk.
The tuner I spoke to today said you can't really tune it out.
He said that on the map tracer when you back off it should jump straight up the vertical axis but it jumps through a few others causing the jerk. This is a problem with AFM cars and this type of turbo. He said all skylines with HKS2530 and GCG etc (that size turbo) do this to some degree.
I mean it isn't that severe but can others try doing this on theres and see if they get the same problem.
I am going to show it to another tuner and get a 2nd opinion
cheers
Edited by benl1981
Hmm thats odd indeed with the stocker.
Is it working correctly?
I know of 3 GCG cars that have no issue... although... the OLD GCG turbo used to surge, the 500hp one.
There used to be two on the market, now there is just the one.
Your still running the stock rubber afm to turbo pipe?
I've driven other R32's and R33's *all with stock turbo's* that all do this under a specific driving condition.
Its not exactly easy to get the jerk and I can't always get it to do it easily. You must only just bring it up on boost then quickly back off but with your foot still on the throttle; the car then does a little jerk; almost like it bogs then accelerates normally again.
A larger afm to turbo pipe helps reduce this.
Adjust your driving style. :)
Yeah will I didn't notice it with the stock turbo. Maybe it's more exaggerated with the bigger turbo.
Sometimes it seems you can get it at a light constant throttle input, but mostly when backing off but not fully.
Maybe I'm being too fussy on this one.
Will show it to another tuner..
Backing off but not fully.. Sounds like exactly like the drivability issue I am thinking of. :laugh:
Try changing your driving style.. Or throw a bigger afm to turbo pipe on it as chances are it will be close to sucking shut anyway.
What your tuner is describing is reversion. On very light throttle you get some back flow (reversion pulse) off the compressor wheel. The only way to fix it is to increase the distance between the AFM and the turbo or introduce a 90deg bend. With the right software it can actually be seen as you back of the MAF voltage gets larger for a second. The majority of AFM's - RX8, any Subaru, some large yank lightening MAFs will NOT run without a bend or a large distance from throttles or turbo chargers etc etc.
I agree with cubes to a certain degree and Rob
It is reversion, the pressure differential between the front and back of the throttle isn't big enough to lift the bov off it's seat.
I only noticed it after i did the stock bov mod and blocked up the little hole. I never noticed it before that, even with an old stage 2 gcg high flow :thumbsup:
Edited by BHDave
  • 3 weeks later...
Ok - I have been checking the map tracer.
At low rpm in 4th or 5th (2000-3000rpm) and around load point 8-11 if you hold a steady throttle input you can see the little black dot jumping around up and down in the same vertical column (i.e. going up hill)...I
It doesn't look normal like what happens in 2nd or 3rd gear.
Sometimes holding this throttle input (around 0-3psi) the load point will jump from 10 to 15 accompanied by a jerk (not sure if jerk is before or after) then back to about load point 5...
I guess this could be a misfire..e.g. the car misses/halts, hence requires less air for a split second since the engine can't take it. This air builds up there and shows a higher load point reading..although this doesn't really hold true unless the car misses which allows more air to flow through..
The air build up wouldn't register a high reading on the AFM
or is the air coming back on itself and the high reading is air flowing backwards..
Anyone had experience with this?
Cheers
I have the GCG hiflow for the last 3 years and have never had this problem.Look at your boost controller,the amount of times I`ve seen people not turn the gain up to maximum is amazing.This creates little tuning problems on it`s own.If you have set gain,turn that up til it starts to spike as well.I did not have your problem exactly but I did have a little hick up on back off in 2,3 and 4th gear and proper tuning of the boost controller fixed it beautifully.Sorry,didn`t think to ask if you have a EBC.My theory is that an EBC is basically a vacume leak,so if gain is to low you may induce a constant boost leak.
hey ben, I get massive reversion on my car. After the 20th, if you like, we can try and see if we can reproduce it, then i suppose you could then say that it would be reversion.
I've also got a gtr bov spare that's going into my car. I suppose after the 20th, suppose you could try wacking that onto your car to see if the bov is the issue. in addition, maybe blockign the bov off all together, just for testing, to see if it makes it worse.
My car seems to have a small issue atm though. When I put the throttle down in neutral, then let go, my revs drop below normal idle. Only started happening around the time I put the pump in (which was 1 week after I put the turbo in). grrr, doing a few mods at once makes it hard to pinpoint issues.
Isn't it possible to 'tune out' some of the effects of reversion?
I had reversion pretty bad on my stock computer, the had the FC installed and tuned and it is mostly gone. You can still feel it slightly, but you wouldn't know if you weren't told.
i've got an r32 with a 2530 and gtr bov and a apexi stainless steel intake pipe (longer than stock by about 5cm)
i get that jerk aswell, but the funny thing is you dont get it so much when the car is cold and running rich.
it used to do the same with the stock bov.
I would like to fix the problem if its fixable
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
