Perhaps you could try moving the vacuum (trigger) for the BOV from the plenum (stock location) to a splitter off the turbo (the one that goes to the wastegater/boost controller).
This MIGHT do 2 things:
1. cause the BOV to open a little earlier ,and
2. perhaps there is a bigger pressure ripple near the turbo outlet pipe that will pop open the BOV with the small pressure differential. (1-2psi)
This shouldn't be too hard to test, let us know how it goes.
To reiterate, you should find the small pressure hose that goes from the BOV to the back of the plenum. Take the plenum end off and plumb it back in as close to the turbo (yet after the compressor) as possible- possibly off a splitter from the boost signal. (Remember to plug the outlet on the plenum).
It might also be that the BOV simply won't budge with such a small pressure change.
OR, it might not be a BOV issue at all.
I'm not an expert, just trying to think it through.
I am using SSQV HKS Blowoff valve and with EVC 5 Boost controller on my 34GTT. The only way to make this jerk dissapear is to reduce the gain on the EVC, however doing this you will not be able to reach you pre-selected boost since the gain is to compensate it. Though this would only happen when my boost is set at .75 to .85 bar. Anything lower then there is no jerk at all. To work around this, i set my boost higher (.8 bar) but still remain the gain setting to reach my .75 bar.
I was told that the boost climb up too fast that we get a slight surge so the ECU will cut the fuel or ignition. Just my 2 cent.
Have a look at the values in those load points for both ignition and fuel. I find quite often that dyno tuners don't pay much attention to off throttle load points. So they leave "untuned" points where there are large changes in values between adjoining load points. Look to have some progression, like 15, 18, 22, 25........not 15, 25, 25, 25 etc. The engine doesn't like 10 degrees changes in ignition timing between 2 load points or 40% more/less fuel.
Reversion with a GCG high flow, I don't think so. I have never seen it and I am personally on my 5th GCG high flow on RB20's, RB25's and RB25 Neos. Plus about 20 or so more that I have tuned. They are simply not that big a turbo.
:) cheers :domokun:
Thanks SK. I just had a look at the hand controller. On the fuel maps there is a jump from 100 to 114 going from load point 9 to 10 in the lower rpm range.
That only corresponds to 14% increase does it? Not close the 40% you are referring to
Doesn't seem linear like the other cells.
Anyone able to tell me if this is normal?
The airflow is jumping around with a very steady throttle input...
Short clip of Airflow jumping around
Edited by benl1981
I think SK has it. I used to have a pretty much perfect tune til I messed with it. Later I got someone to touch it up. He removed quite a bit of fuel in some low load points. That seemed to introduce this jerk you guys are talking about.
I was going to (one day :)) tempoararily richen the whole map to test if it was simply the AFR but I see now it might just be the difference between tuning points.
As I think I said previously.. when i get this little jerk my load points increase, tracked down to the afm being disturbed by the plumb back bov or no bov (when I blocked it off the problem became worse). So watch the map trace when it does it and see if your issue is the same as mine. :)
A larger and or slightly longer afm to turbo pipe 100% sorts this problem.
BUT SK may be on the ball with his suggestion to check the tuning.
Cubes did you fix your problem with a longer pipe. THere isn't that much room there though.
Yes I see mine spiking down vey high on the map trace when this happens sometimes. 4800mv by 3000rpm - I don't think so!
What sort of turbo do you have cubes?
Also,
Can other people tell me when they look at there map trace if they give it a bit in 2nd or 3rd for a few seconds (till about 4000rpm) then back off does the map trace jump straight back right up the top. Mine jumps through some other load points on the way, then once it hits the top it sometimes jumps down again for a second even though the throttle is still fully closed. Not sure if it did this with the stock turbo.
At lower load points when I back off it jumps straight back up the top.
Thanks
Edited by benl1981
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
