yep after more than 8 years, finally sold it, hope the new owner will enjoy driving the car.
the last pic :D
shopping list:
rb26 engine out of late 32 gtr
oversized wiseco forge pistons
shotpeen rods
new rb26 crank
n1 bearings
n1 oil and water pumps
rb25 sump+baffle
custom twinplate clutch
rb25 gearbox
modified tailshaft
tomei 260 cams+cam gears
ported head
o ringed head and block
hks gt-rs turbos
nismo plenum
splitfire coils
bosch 550cc
malpassi fuel reg
custom fuel rail
2 x 044 and custom surge tank
greddy ic piping kit
greddy type r bov
ARE custom intercooler
custom radiator
cusco brake stopper (woo rice!)
34 gtt brakes front and rear with "some" mods to fit under 16inch gtst wheels ;)
32 gtr wheels+toyo r888 tyres
bilstein shocks
hicas lock bar
J's Garage/v8skylineman custom coolant hoses fix0r! (thanks mate!)
J's Garage/v8skylineman custom front number plate bracket!
J's Garage/v8skylineman custom front bar fitting!
greddy profec b at 1.3bar
motec m8 tuned by matty spry
custom twin 3inch exhaust from turbos, 2 x racing catalyc converters , joined to 4 inch near the diff by hinterland exhaust
all mechanical work done by gavin woods autotech
I'll add more if I can remember anything else.. :P
oh before ricers asking for rwkw figures.. it makes 90hp in n/a mode, so there.
Edited by japtaxi
https://www.sau.com.au/forums/topic/169299-sold-my-32/
is that with or without the double shot of nos?
sweet car man, care to say why u sold it with that extensive list of mods?
aww man i forgot to refill teh nawz bottlez doh! :P
I don't drive it any more so might as well let someone else enjoy it ;)
You really had it for 8 years. Far out man. Thats ages.
So what do you have now?
i'll get my other project car on the road again.. 660cc 3cylinder powah!
sad to see it go willus... only wish I could had afforded it...
oh wells...
ed here's a tissue :D
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3129484
Sooooo quick over our private test course ;) it's an awesome car Will, Michael is extremely happy. Was funny coming home after the mountains watching the speedo sitting on 0kmp/h :laughing-smiley-014: gets to 180, then back around to zero rather quick
awesome! :) those tyres made huge difference to the car now..
glad he put it to good use and blow the cobwebs out of engine :)
0 to the other side of 0 is lotsa fun :) the speedo is funny too.. it jumps around every now and then I think :)
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3129973
0 to 180 to 0 is nothing.. 0 to the other side of 0 is more fun :)
we could only 0 to 0 at 7000rpm in 5th gear then ran outta road :) Need to find a better/longer road to 0 to 0 off the limiter ;) Those tires are monsters, so much entry speed and even more exit speed! Just hugs in and bites like a mofo and leaps forward.
Flames FTW
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3129978
we could only 0 to 0 at 7000rpm in 5th gear then ran outta road :) Need to find a better/longer road to 0 to 0 off the limiter :) Those tires are monsters, so much entry speed and even more exit speed! Just hugs in and bites like a mofo and leaps forward.
Flames FTW
What tyres are they?
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3129998
I was seriously thinking the car had gone slower as it doesn't spin or flick out the rear as often with those tyres :)
might have to get a set for my other cars too now :)
Edited by japtaxi
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3130039
should'a kept it, just keep buying other cars instead
I did that for a while, but ran out of garage space :D
Congrats on selling it will, I believe that was the skyline you dropped my parts off in making it the first SAU skyline I had seen.
hey adam ya should'v bought it at first place instead of fixing little things :blink:
Edited by japtaxi
https://www.sau.com.au/forums/topic/169299-sold-my-32/#findComment-3133024
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
