  • Replies 41
this guys a disgrace to all mathematicians
i remember i was drunk and i saw this guy and i was yelling out abuse to him
hahaha same!
me chris andy tuyen all in the car, most of us highly intoxicated, chasing it down James St one night yelling abuse.
good times.
https://www.sau.com.au/forums/topic/169537-11-7/page/2/#findComment-3148040
Haha i saw this ar in northbridge at like three in the morning and forgot about it till like 3 days later when i went through the pics in my phone and i was like
WTF? I DONT GET IT
If you have pics, post them up... I never go into the city so have no idea what you guys are on about :woot:
https://www.sau.com.au/forums/topic/169537-11-7/page/2/#findComment-3150765
  • 1 month later...
Well we know 1+1= 2 and 1+1= a window but what if . . . just what if 1+1=11 and that this guy took the 11 and put it behind a 7 to make the shop name 7-11, but it still dosnt explain how he got the 7. . . . maybe he has only 7 friends and they like to hang out at 7-11
I dont really know haha . . . its late and im tired
https://www.sau.com.au/forums/topic/169537-11-7/page/2/#findComment-3241195
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
