I am currentley looking at replacing the solid fuel lines in my car, one bigger lines, more fuel, the obvious. But also as everything else will be braided lines and screw on fittings it would be kinda nice to be able to screw these lines into the solid ones instead of using homo little adapters and clamps and stuff.
Now I suppose my actual questions, how much power will the standard lines flow as opposed to say a -6 or -8 line? and how the hell do you get the lines in and out, is there a way to do it without dropping the entire rear cradle out?
https://www.sau.com.au/forums/topic/169667-fuel-lines/
yeah, just cut them.
Do you have a fuel problem atm? if not, then why bother changing?
then how do you get the new ones in.......
At present yes, with bigger pump/injectors maybe not, but as I said I wanna know how much power the stock lines flow.
https://www.sau.com.au/forums/topic/169667-fuel-lines/#findComment-3135693
i can tell you for certain if you are using 700cc injectors then the standard solid lines will not be posing a restriction for you.
awesome >_<
hmmm still kinda gay having to use those little adapter thinggys, ah well dunno if I can warrant the expense to get the lines redone just to get around it.....
https://www.sau.com.au/forums/topic/169667-fuel-lines/#findComment-3135885
I hear alot of discussion about using the hicas lines if its disabled. Weather this is feasible i do not know.
that trick only works for r32's that have the hydraulic hicas.
i ripped my stockers out on the weekend, looking at them, they are only 8mm each! :) replacing them with 2x -6 feed and 1x -8 return. just use a pipe bender to bend the tube into shape, shouldnt be all that hard :)
also if u wanna get rid of the stock rubber gear in the engine bay and kepe the stock tube lines under the car, u can use speedflow fittings from the tubing to braide, piece of piss really >_<
https://www.sau.com.au/forums/topic/169667-fuel-lines/#findComment-3136203
also if u wanna get rid of the stock rubber gear in the engine bay and kepe the stock tube lines under the car, u can use speedflow fittings from the tubing to braide, piece of piss really :happy:
yeah making the lines is no problem it's just getting them in and out :)
yar those little fitting jigger things, just a shame to have all screw on fittings then use rubber pipes and clamps to join to the lines under the car....
The stock gear i believe leewah used for 600rwkw.
It'll be decent enough for you :laugh:
That makes me happier about using the stock ones, as I said before though still a shame to have to use those little jigger fittings.
https://www.sau.com.au/forums/topic/169667-fuel-lines/#findComment-3136517
  • 10 months later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
