Hey all, my turbo blew on my 33 series 1 yesterday and it obviously needs to be replaced. Im wanting to replace it with something bigger/better or get mine highflowed and rebuilt. Got a few questions
1. How much am I looking at for a rebuild and to get mine highflowed. Im in Brisbane any good places?
2. I will have a budget of around 1k for a new one, what turbo should I be looking at getting for this price?
3. How vital is it to get your car tuned if I replace it with an aftermarket turbo? (I have standard everything)
Any other helpful advice you wanna pass on to me about replacement turbos etc would be very much appreciated guys. Still learning about it all.... Thanks for your time. Here is my email if anyone wants to help me out on msn.
[email protected]
Thanks again.
Jamie
https://www.sau.com.au/forums/topic/170262-replacing-r33-turbo/
get a sliding performance high-flow jobbie
but you'l need an aftermarket computer, fuel pump, intercooler, injectors if you want to make the most of your new turbo, also your stock clutch will need replacing in no time :wub:
and a good tune !
Edited by SiR_RB
if uve only got 1k get a high flow from slide, as a gcg or equivalent ball bearing one will set u back at least $1500. u will definitely need an aftermarket computer or piggyback. ud also need a bigger fuel pump and some injectors or at least a fuel reg.
What birnie said is spot on the money. Agreed 100%.
Putting in an aftermarket turbo without a tune is not recommended for a few reasons. It's not really safe (if the airflow is in excess of generally what's safe. As birnie said, if boost is lowish, it MIGHT not be dangerous. This leads me onto the next point.
It is of no benefit to have an untuned computer wiht an aftermarket turbo. It will be slower, both because the ECU can't handle it, as well as the fact that naturally, a bigger turbo is less responsive.
At the moment, I've got a highflow on my car untuned, and it's a lot slower.
so at a very minimum, you're looking at least at the cost of a new fuel pump, ecu, tune, turbo, clutch (won't handle the power), tyres (traction for the power), maybe wheels, diff (better traction), suspension (traction), exhaust, cat, intercooler and boost controller.
Injectors and MAF would be recommended too to take full advantage.
Another vote here for the Slide hi-flow
When you say your car has "stock everything", does that include exhaust and intercooler?
To get the best bang for your buck and semi-decent results, you will at least need a turbo back exhaust and a bigger intercooler (front mount or maybe R34 sidemount), as well as some type of ECU (even a piggyback like an SAFC will get you bye).
$1K isn't going to cover it really, as you're looking at that kind of money just for the hi-flow. Cooler and exhaust if you shop around/buy second hand you can probably pick up for another ~$700, ~$200 for an SAFC, then installation (if you can't do it yourself) and tuning (~$200) on top of that.
This kind of setup on a lowish boost level (11 - 12psi) should see you around the 200rwkw mark, but a stock clutch isn't going to last long at that power level.
Fuel pump, AFM, injectors should be fine until you hit 220rwkw+
Thank you heaps for the help so far guys, its opened my eyes a bit! As I said still learning about it all so sorry if I ask stupid questions. Ok so, if "light" driving and just taking it easy in the car for a while as I do anyway, will I get away with the following, while I save for the rest.
1. No frount mount.2.Standard clutch ( when you say my clutch should be replced is this because its going to slip from more power? Or your all just assuming im going to be drifting and doing burnouts?)3.Standard fuel system.4. Piggy back ecu ( IS that what the SAFC does?)
I have a turbo back exhaust (with standard dump pipe), Blow off valve, 2 way locked diff, Pod, so when saying stock I meant just had the usual sorta mods. Ok so what I really want to know as simply as you can put it, is this.
1.What are the bare necesseties I need (Try help me out with specific brands, and direct replacement turbos please or if its a better option to highflow mine?)
2.Around how much am I looking at (approx)
3. And where can I get it installed in brisbane! (and cost to do so) I can do the turbo,
Thank you so much guys your really helpin me out here. Elaborate and explain as much as you can on the above points its all helping.
Jamie
Jamie
Don't bother with a front mount or after market clutch if you haven't got that much cash to play with. An r34 side mount intercooler is always a good up grade for up to 220rwkW.
A high flow is a better option than putting another standard turbo back on because it might break in month, you just don't what condition it'll be in. A direct replacement if you mean aftermarket will be far too expensive.
The cheapest way out of it: standard turbo $300 + $300 labour (maybe, not sure though)
The most sensible way out it: Slide standard hi-flow $890 exchange + safc $210 + 300 labour + tune $200.
As for shops just ask around, friends and other skyline owners.
You can put a Highflow, or just plain bigger turbo on without doing anything else, and as long as the factory (or equivalent) Wastegate actuator (5psi crack-open pressure) is used, the factory ECU will have no probs. In fact, it'll probably drop close to a pound of boost in the top end, since you won't get the stock turbo's boost creep.
(Explanation: The stock turbo has a tight exhaust housing, and small exducer, which means that nearly all the gas going through there is forced to work HARD spinning the turbo faster. When the wastegate can no longer bypass enough exhaust gas around the exhaust wheel at high load/rpm to properly limit what goes through the turbo housing, U get runaway boost creep. My stocky turbo made 10psi with only mods being FMIC and full exhaust)
Oh - and you'll find any other turbo quite laggy after the stock, especially if You've experienced full-Xzorst with stockie, 'coz MAN those Ceramic wheels spin up FAST ! ! I was seeing full boost around 3.000 RPM with the stockie, in 2nd !
Thanks mate, nicely set out for a learner like myself! Are the sliding perfromance highflows just standard highflowed turbos, if so will it be fine to just throw one right on?? Are they ball bearing?and a direct replacement item? Where can I find info on them guys.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
    • I can't speak for the US, but for Canada as I mentioned above, all fuel gases contain ethanol. We have regulations for E5/E10/E15. Each province handles it differently but basically any fuel gases sold must be E10 and slowly increasing to E15 by a certain year.
