Hey everyone.
I didnt really know where to put this i just decided to stick it here. I seem to be having a little ant trouble with my car. They are all over the body of it and my guess is that they are walking up one of the wheels and the climbing up some how. I washed the car yesterday in the hope i would kill them all and then parked it in a different spot and they still seem to be hanging around.
Has anyone had a problem like this before?
Anyone know what i might be able to do? I just dont want to mess up my paint.
Al
https://www.sau.com.au/forums/topic/170530-ant-invasion/
Hey everyone.
Al
They hang around because they like you. No not really.
They actually nest in the car. Happened to my pulsar when I had it.
They used to eat my chewing gum.
I'd go to have a piece of gum and it'll be all munched on already.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3149036
Just normal car wash. I cant tell you now cause its at home. Yeh i think they came up on the tires and then on the suspension.
My real worry is, do you think some sort of surface spray will damage my paint, especially cause its white and i dont want residue or shit on it.
I dont thik they are nesting in my car. At least i hope not.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3149207
hey mate ive never had an ant problem in my car before, but can tell you that these ant baits are probably your best bet, even over some sort of surface spray or similar...
Whenever I have an ant problem at home, I use Ant-Rid liquid formula.. looks and smells like honey... and basically wipes out the entire nest as the ants take it back to the nest with them...
the only thing with it is you will probably end up with a few ant carcasses here and there... I think the majority die in the nest, because I never seem to see as many dead ants lying around as there were feeding on the stuff... so this may be a problem if the nest is in your car..
anyways website -> http://www.antrid.com.au/products.asp
can be bought from most supermarkets..
good luck.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3150394
make sure they dont nest in your car... i work at a honda dealership and one of the cars had a problem and just wouldnt start anymore.. the ended up pulling out the ecu and opening it up and guess wat they found in there??? an ants nest... let me just say that it was very expensive for the customer
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3150601
Hey everyone.
Al
What a stupid avatar.
you're dead to me..
Edited by Driver
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3151116
I had this happen not to long ago, removed some tree roots from under where i park my car then when it rained next it flooded the ant nest that had been using said root for flood protection. They were everywhere over the outside and in the engine bay. I used surface spray in the enginebay and on the wheels as for the bodywork everytime I went out for a cigie Id squish all the ants I could see. after about a week there was no more ants. And to stop them coming back a coverd my parking spot with ant-sand. Haven't had a problem since.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3153134
Hey guys,
I just found the next and there are shit loads of them. The nest is inside the passenger door. They seemed to have gotten in through the drainage holes at the bottom on the door and i am about to go jihad on their asses. Thanks for the help
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3155671
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
