i was reading on a skyline mod page that swapping a stock gts25t intercooler with a r33 gtr intercooler was a good upgrade to performance and easy to do and doenst hurt the wallet as much, what are peoples thoughts on the matter and thinks or worthwile or any other ideas?
depends how much it costs...... 349 just jap intercooler kit may be a better deal though
Any front mount will require a fair bit of front bar modification..
I got the just jap kit 1/2 installed. It is a bit of friggin round but I think they all are.
Good thing is the jusjap kit comes with all piping.
If you are staying with stock turbo I highly recommend just the R34 SMIC.
FMIC is a lot of stuffing around!!
Otherwise I've heard people on here doing the install for $250 which is a bargain.
So if you want FMIC:
DIY - $350
JustJap + Install ~ $600-$700
Performance gain on stock turbo <10rwkw over R34GTT cooler
Unless you want the wank factor..
exactly what benl1981 said, except for one thing. there's no KW gain over the 34smic unless ur stock turbo is nearing 220rwkw.
wank factor plays a major role in the amount of front mounts you see around.
Unless you're planning to go for over 200kw I recommend a R34 GT-t side mount intercooler. Better, bigger intercooler and it's a direct bolt on fit.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
