Hi all,
Am new to SAU and kinda need advise from you guys
What do all you think for this :
http://www.drive.com.au/used-cars/NISSAN/S...p;SG=-898480144
Questions
1. Is Fuji MotorSport reliable as in trustworthy and not being dodgy -i.e. hidden dents, rust, marketing talk, etc if you know what i mean
2. Am currently located in Perth. What's the best method/company/procedures to ship the vehicle over?
3. Is the r34 a series 2 ? (am assuming this given that there are no red markings on the neo engine however the gauges in the interior kinda looks like a series 1 ). Are there any other ways to distinguish a series 1 from series 2?
4. Would it be recommended to acquire the said vehicle via a dealer or a private seller ?
Many thks in advance
Edited by hotchoc
https://www.sau.com.au/forums/topic/171096-new-to-sau/
check out http://www.www.imports101.com.au
they are a local company that imports and complies skylines and usually have a good selection of cars in japan to choose from or you tell them exactly what you are looking for and they will do their best to find it
i would hazzard a guess at the speedo being wound back so that speedo reading wont be truly accurate
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3156835
Yea, am very sure the kms has been winded back for sure. What series is the skylien anyway ?
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3156853
Welcome to SAU.
The 34 there "looks" ok but its in sydney? By the time you get it here to perth (i use Wridgeways coz my wife works there :) ) register it etc etc i cant help but think maybe you can pick up a better deal locally from one of the perth import dealers. Not going to list them all, but Imports101 are very good, even check out Autoworx. Thats 2 that i have personally dealt with on different things and recommend them both highly.
Good luck with your purchase dude.
Cheers
Brad
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3156883
How's imports101 service btw?
If the broker in Japan were to supply a bs car to the local broker over here (i.e. rust, peelign paint, not as advertsied), is there anyway i can reject the vehicle or is there a must for me to accept it regardless of the condition ?
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3156888
when importing you rely on the broker to find you a car in good nick. Imports101 and Autoworx for example have good reputations for finding cars in good condition, specs etc. i bought my car from autoworx and couldnt be happier overall and mate got his 32 from imports101 and was happy as far as i know so you can be reasonably safe with these two if you go with them
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3156939
SII Front bar :
SII guages , wheel , trim :
SI :
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3157233
are you particularly chasing a sedan?
i gots a coupe coming up for sale. soonish
Learning about them means a coupla things.
This forum is going to be godsend.. It can also be a hindrance if you let all the opinionated L platers have a say.
Easiest way is to think about the questions you may have..
So performance pathway... search forums for R34+power or r34+performance etc.
Wanna know about interiors search for that.. see if there are any issues. check out the interior group buy for leather interior. you will have to sift through pages.. but you will read about what bits break etc.
Or check the audio section..lots of people scratching interior panels etc, or removing things incorrectly and breaking them.
Its just gonna take alot of time, but the info is all there.
a few guys along the way in other parts of the country have done ALOT of the trial and error stuff on the 34's
good luck
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3163867
good luck
Cheers mate. Actually been doing that for the past few weeks. Lucky there's thsi forum. Soon am gonna come up with HEAPS of questions :D
https://www.sau.com.au/forums/topic/171096-new-to-sau/#findComment-3164454
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
