so i got a 25 in a 31
hit 2k and the car just bounces back, revs just die back down
car idles high and over fuels
doesn't matter weather you load the car up or free rev it no difference
i tested my spare AFM as per what the r33 engine manual says, i have tried 2 AFM's and had the loom checked and its all good
what could be my problem guys?
sometimes the problem comes and goes, well it used to and now it wont, sometimes you could start the car and drive it and rev its f**king ring out, then you could turn it off, turn it back on 1 min later and it would idle high and not rev
i really need help this car has been on the road like 2 weeks in 14 weeks and its shitting me
either talk here or add me to msn please
[email protected]
thanks people
i ran my piping from turbo straight into intake to make sure none of my piping was f**ked
no difference
but when i have popped pipes off ran different to this
lets say your driving down hill, hits like 2.5k and just makes a bovish woosh noise, then nothing, then you change gears and same shit
Edited by Rednisr31
did u check to ensure the afm has got dry cracked solder point? if you checked, do it again, only this time use a soldering iron to heat up the solder points. this will ensure there are no under lying cracks.
take it to a tuner man and get them to diagnose, might be worth your while to get a safc2/neo and tune with that, will eliminate some issues and youll be happy. all up prob will be fixed with around 500 odd.
yeah... i think im going to have to
bit of a bummer, i may leave it cause im taking the engine out of it in a while and putting it in a 32, getting an aftermarket ecu at the same time, but i dont have a car to drive atm
