Hi
My car failed Roadworthy check today as the mechanic cannot find the build date or year of the car.
The car has a Blue Mod Plate with L01 code on it and the australian chassis number but no year.
The Blue nissan plate has no build date as well.
Where can I find what year is my car? to prove it to the mechanic and QLD Transport.
Please advice.
Thanks heaps in advance
the car was imported privately and was complianced and plated with the qld mod/blue plate with L01 code and it doesnt have the build date on the plate.
nothing on the door as well
how do I prove this to my mechanic?
thats not a compliance plate its a mod plate, much lik an engineers report in nsw etc
i can suggest have ur vin fasted that should tell u otherwise i dunno where it would say........
get ur vin and put it in there http://www.skylinesaustralia.com/forums/in...8496&st=400
in QLD it is and under 15yr private import they have it on the "Mod Plate" but code is L01 for Australian Design Rule Compliance
I just want to know how to prove this to my mechanic, he wont look at the computer...
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
