Stops your engine moving around.
Increases horsepower and torque...
You will see it most effictive in an SR engine tho.. They move around a fair bit..
Esp if you got cams etc etc.. for 80 bucks from justjap.. probably a nice little upgrade
You might as well get the brake fluid stopper thingy..
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162589
i think hes talking about a master cylinder stopper,
its basically a bracket that mounts to your strut tower with a plate or bolt that press up against your brake master to stop it flexing against the firewall when you hit that anchors.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162610
Edit: ^^ yea what he said..
so stops your brake fluid from moving around all the time when you brake hard or go fast around a corner
^ brake fluid right? hmm yea think thats what it does..
Edited by siddr20
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162614
I havnt noticed any in my friends worked up s15.. thats got cams etc in it..
If you got adjustable castor rods like me, then you can feel those thru the cabin lol..
not to sure about engine dampers..
Edit: pm PLYNX.. hes got one in his 33.. ask him if he feels anything!!
Edited by siddr20
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162624
I'd hope they save engine mounts.
I've done in one set of new engine mounts. :D
A mate in his GTS4 also did a set of engine mounts.
The Skylines appear to be fairly well setup; even with a busted engine mount they don't move around that much. Previous v8 aussy cars I've owned have the whole shifter moving often cracking your left knee. :S
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163203
I put in a HPI engine damper in my car and had it on for 3 years+....... i reckon it was a waste of money IMO. haha
i do circuit/drags quite a few times a year and with 135,000kms on the body. engine mounts still seem fine..(ithink)
if i had the choose again i rather put that money elsewhere but i dunno .
As for vibration in cabin.. feels the same to me.....
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163247
they hardly do shite on RB's as the attachment point is a flexible bracket (factory lifting pont).
this is all you need to know.
everytime I've tried to buy one in japan my (knowledgeble) friends there have talked me out of it. When I asked if they were good his exact words were: "looks part only". meaning it's just useless bling. if you like the look by all means get one. if you want a stiffer mount for your engine just use the nismo engine and box mounts.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163270
lols. a brake master stopper doesn't stop brake fluid moving around. it stops your firewall flexing when you are hard on the brake pedal.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163456
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
