hmmm yes you would say that, what i was just after was just some positive/negative feed back from people who have them installed, i know how they work and why you should put one in, but i want to know from drivers what they think.
how much do you sell them for?
acually one question, do they put any stress on the clutch packs in the transfer case.
Edited by robbieraver
details of our controllers are in the link in my sig, and I don't want to make this a for sale thread...
First up, if you are only looking at street driving there's probably not too much point. Where they really help is allowing you to tune the balance of the car in corners, you have the car's natural balance, tyres, suspension and then you can get more or less fwd to change attitude on corner exit. Also obviously helps in the wet with reducing wheel spin, presumably the same for big hp gtrs in the dry too.
Yes they do put more stress on the clutch packs, you can burn them out running too much front torque for too long - they are not designed to transfer significant torque all the time. We killed a transfer case at targa tas 2 years ago on a 50klm stage through snow running full front torque all the way.
In the end, the 32 had too much rear bias and a controller can fix that - you leave it on say 3 or 4 and enjoy the improved balance. Nissan obviously agreed they changed the system to have more front bias in the 33 and 34 - I have a stagea daily driver and it's front bias is much more than the 32 (it happily power understeers every time you floor it)
i run a torque controller supplied by duncan
and it works very well for us, we have done alot of racing over the two years it has been in the car(hillclimbs, sprints & tarmac rallies) and we are still using the original transfer case and we have not had to rebuild it.
i will say one thing though, if you 4wd system is not working properly (as most r32's aren't when they get to this age) all a controller will do is speed up the process of destroying your transfer case
oh & another thing, we did try a different torque controller that used a dial with percentages(10 stage adjustment) being directed to the front, this was a very sensative system and if you dialed in too much it would have killed the transfer case in a heart beat on circuit, not as bad for drag racing though.
cheers russ
Edited by giant
thanks for the info, that is the same sort of driving il be doing, not so much targa but hill climbs and track work, ive heard of one or two dead transfer cases down my way (melb) but thats some thing to keep in mind.
cheers.
Take you GTR to Racepace then.
They modify transfer cases inhouse :rolleyes:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
