ehe, yes you do have a problem with economy...
If it is hunting at idle (always fluctuating revs) then im sure its your O2 sensor, if I were you though id be more confident with a second opinion from another person on the forums here...
manwhore wats the max latency that the injector cycle should be on consult, I have a greddy intelligent informeter and Im trying ot configure it to show percentage injector duty cycle and then set warning points. i love this thing... lol.
yeah cheers, when cold (anywhere under operating temp) it does hunt at idle. Think ive got an o2 sensor off my old 32 here might give it a try, cheers :woot:
"Hunting" is generally a sign of a gummed up AAC valve. And the O2 sensor is unlikely to be used at idle, or when the engine is not up to operating temp. So, if you only do short trips that don't get the engine up to temp properly, then you are going to chew petrol.
How to test - check the voltage coming off the middle wire of the sensor - it should be oscillating around 0.5V (say 0.3 - 0.7). If it is constantly high (1V) or low 0V) then there is a chance your O2 sensor is cactus.
You might also want to check that the sensor is getting 12V on one of the other 2 wires.
multimeter is the way to check. takes 2 mins.
measure it at idle, give it a rev, and hold it at a sustained rpm, say 2500rpm.
see if you have fluctuating volts
last skyline i checked (a friends) it was dead as a doornail, got no change in volts. replaced it and the car got an extra 50-80km's iirc (hopefully you gain some more!)
also on my skyline i changed spark plugs, cleaned afm and got new coilpacks, that gave me 2L / 100km better economy! my plugs were old though
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
