I just installed an atmo bov HKS SSQ, and blocked the return pipe with a nice blue bottle cap.
And now Im having the common stalling issue on my R32
car is stock aside from the obvious bov
I know I can just switch back to stock bov or plumb a return line on the aftermarket HKS
I've read some people dont even get this problem (lucky bastards!!!)
How do I adjust the idle to go higher a little bit?
dont really wanna buy an aftermarket computer right now too much $$$ from buying the car.
I'd give it a few weeks and I'll go back to stock, I just want to enjoy my 1st turbo car but dont wanna stall everytime i press the clutch or stop at lights.
My HKS bov is one of the 1st series that doesnt have the adjustment bolt to tighten the valve/spring.
here's the pics after install
Cheers
https://www.sau.com.au/forums/topic/171836-hks-ssq-bov-stalling-issue/
For starters, note that BOV's are illegal - a bastard copper will give you a defect notice on the spot plus a nifty fine if he catches you UNLESS..... you get the drift. Does hide and seek mean anything to you?
And no, sorry, I don't have a HKS SSQ so can't help - I got a Greddy one.. makes the meaniest sound... it's like..... VVVVVVVVVOOOOOO TU TU TUT TUTU UTU... LOL
yeah spunky munky is out on a post count mission im pretty sure,
you will find pretty much any atmo venting bov will give u stall issues on a stock line, best thing to do is put up with the stalling for the three months it will take u to get over the friggen noise then go back to stock haha.
goodluck man :action-smiley-069:
had the same issue with my car, everytime i clutched in or stopped the car. it would stall. but this only hjappened after hard accell. normal driving its fine. i have a PFC and thats the only way i know of putting the revs higher. my revs sit at 1000rpm
as aposed to the normal 800
I had the same problem mate. Mine did get better over time though as it seemed to happen less and less. I had the old style HKS Sequential BOV and I just tightened the screw up more and it seemed to go away. Maybe give that a go?
my SSQ doesnt have the adjustment screw/bolt
Today adjusted the idle speed and it didnt stall all the time only once when it wasnt even boosted...funny
I set the idle to 800-900 rpm and seems to be OK but still stalls
I've read that I can use HKS Electronic Idle Stabiliser to overcome this issue.
Might give that a try...
or the more expensive Apexi SAFC
Edited by Rob_C110GTR
or just save urself a few bucks and go back the stock bov. the issue is ur venting out the air your afm has already measured and this is making ur car run like crap doesnt matter what u do without some sort of air flow/fuel correction your cars gonna stall and be crap to drive. is it really worth the sound??
as I explained from the 1st post I'd like to have it for a weeks then back to stock BOV
just to experience it, Im pretty sure you did as well with your 1st turbo car...
so enough with going back to stock BOV
i know that already
just wanna try and make the stalling a bit bearable.
Cheers
oh ok then nah worries. yeah i had a blow off valve experienced your probs and took the thing off after 1 hour of having it on. But hey people buy turbo cars for different reasons. Best bet for you would be to buy a cheap safc from ebay it wont make the problem bareable it will fix your prob completely :) good luck.
Having a PFC will FIX the problem,
If you have a PFC and your car still stalling then your TUNER don't know how to TUNE the PFC properly. Apart from that, atmo bov will stall your RB25 as everytime you change gear, the stock ECU will dump a bit of fuel in and now there is no return air, all the suddem your car runs so RICH.
the reason no one ever bothered to solve the problem was that in the end we all realised how pointless it was to try to fix it. You can spend hundreds of dollars trying to solve this problem, buy this and buy that when you can simply solve it for free by putting the stock one back on. For most people, the novelty of the sound wears off after about a couple of weeks and the problem sovlves itself.
I don't know if this will help,but, i read a post a while back about this guy using his stock BOV, and having a vent to atmo. BOV just after the Intercooler pipe. ? you'd have to get a exhaust shop to install it for you and you should be alright. please correct me if I'm wrong.
good luck mate.
Aif
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
