Yesterday I was about 100kms out of sydney and couldn't wait to get home coz I was as sick as dog from a stomach bug. it was pouring down rain and freezing when the R32 (gtst) which had been running without a hic up just started to cough and splutter and I came to a stop by the side of the road. here are the symptoms Idles very rough if at all, revs no more than 4.000 RPM loads of black smoke. one small thing i did notice is that although i could hear the turbo spooling I couldn't get it to boost, (stuffed turbo maybe) checked all hoses and pluges and everything is fine.
any help would be greatly appreciated
thanks heaps James.
https://www.sau.com.au/forums/topic/172039-the-old-skyline-died-help/
it could be bad fuel sparki, coil, leads, or blocked fuel line, filter or injector since it happed in the rain, water could of got into ur engine bay causing a short some where. happed to me one rainy night after work drove home and my car had the exact same prob except it had a missfire, next day it started up fine.
Edited by Greekos
Thanks for all your help guys and yes it was the pipeing. just on the inlet side of the intercooler the clamp had split and the silcon had a nice tear
down the middle (cheep kit you get what u pay for).
So thanks again guys :) James
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
