Unclip the front cover
Remove the 3 screws holding the button section to the unit and remove the button section.
Remove the 2 screws holding the board in place. Push the back of the 4 lights either side of the gang connector to the right of the display. This will push the board out from behind and unclip it from the connector.
Remove the globes
Fit the LEDs, they’re very snug and may click into place, once in, rotate them to lock them into place, may be easier to push with your finger nail.
Push the board back onto the connector, plug the unit in to make sure all the LEDs are the correct way around an illuminate. If any don’t light up note which ones they are and replace them turning them 180 degrees. Retry and confirm you’ve got them all the right way around.
Now there are 2 options, you can either remove the light diffuser so the LEDs don’t foul on the inside of the unit (some clever angling of the LEDs will get perfect dispersion), or modify the light diffuser by drilling/melting out the section where the LEDs line up.
Once done, replace the screw and put back together (reverse of taking apart)
Hi Dan,
what does this mean? do i have to do this? and why?
Cheers
Hi Dan,
Cheers
The lights being so bloody tiny in tungsten form only have a small area to sit, with the LED type they are slightly bigger so need some extra room made behind the diffuser...this is the only option I'm afraid.
Dan
  • 1 month later...
  • 5 weeks later...
would i loose much light if i removed the light diffuser? intead of drilling/melting it down?
what he said? can any1 confirm which method works best?
oh and pics of finished results would be awesome to :)
Ok, just did mine last night. You need patience to do this.. it kinda gay for something that should be easy.. how many people does it take to change a light globe kind of thing.
So.. I pulled out the A/C unit. Took the front cover off it and Unscrewed the circuit board. Spent a few mins figuring out how to get the circuit board out ( you do need to get it out). Take 666dans advice here and use a screw driver and push on the back of the old globes and the circuit board pushes out with them.
so.. i put em all out and put the LED ones in (either use your thumbnail or a large flat blade screwdriver to push and turn them in) Went back to the car with it in pieces still and tried it out. Shit.. i was unlucky with the 50/50 chance and got them all the wrong way. Pulled it out and turned all the LED's around the other way. Test again.. they all lit up. Hey they are really bright!
So thats kool. Now to get the cover back on. It wont fit with clear plastic diffusers in place so i took them out and tried it out in the car again. Wow that looks totally shit.. can barely see most of the lights and one is stoopidly bright. This is the point i went inside and read this tutorial properly. hmmm... seems that people had sucess with moving the LED's so they point in certain directions.. tried this and it looked better but still crap.
Well, looks like ill have to modify the diffuser. If you try and keep the diffusers in there with the LED's it will just squash them and pop them out of the socket. you DO need to make more space for them. Now i thought i would be a smarty and file the end of each LED down using sandpaper and that would give them enough room so sit in there. It would also disperse the light better. Nope.. it was a lot closer but still not enough room. Used a drill and VERY VERY carefully drilled down until i was just touching the 'V'. This will only make sense once you look at the diffuser closely. Tried it again. all good.
Final results.. it works and i can see the buttons now. Its not very bright though but thats a good thing. If i could find the stock globes i would buy them to save most of this hassle but it does look ok
the exciting part about it is that i can actually SEE the controls now. Before this i was fumbling around in the dark pressing all the buttons. Colour does match the dash cluster now :thumbsup:
looks awesome bro!
  • 1 month later...
  • 3 weeks later...
i bought normal globes from genuine holden spare parts they're exactely the same except with a black base an green sleeve, i think they're in VT's but just take the globe to em an they'll know
  • 1 year later...
  • 2 months later...
  • 1 month later...
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
