I've done a search but not found much related to my problem(s)
yesterday afternoon i noticed my steering went very heavy, tho in the morning it was fine.
this morning when i go to turn car on my front torque goes up and off the scale.
i'm unsure of that system i should be looking at to fix this problem.
please help :)
Edited by Angus Smart
https://www.sau.com.au/forums/topic/172137-32-gtr-problems-please-helppppp/
just tried to drive. fuel, oil pressure, rpm, and the torque one that goes to above and beyond do not work.
i've tried to get into the hicas fault check but it does not work..
car has the tomei lock off kit.
also windows wont go down.. soon i'll have enough here to write a novel!
its always heavy, doesnt change no matter how slow or fast, tho obviously it gets easier when your moving. but its still has the same force to turn.
this is the only problem i have now all others are fixed. but i'm still stuck :)
Have you tried to do the hicas diagnostics since replacing the dead fuse?
If you can't get into the diagnostics, you will have to start probing with a multimeter. Solenoid drive signal to steering rack, solenoid ohms, speed signal to hicas module, power to hicas module. Pick all the ones you can get with a meter, following the manual, and if you run out.. then try replacing the hicas module with one you know to work from a mates car.
james.
ps. you haven't got a thing on the wiring issues I'm having to sort out with this one.. rb20det AT, converted to rb26dett MT with wires deleted, twitched, taped, aaargh. good luck though.
Edited by heller44
Haha i figure i'll need a hoist for that right? to check all them voltages. i might find someone i know with the diagnostic tool also. which would help locate the problem(s) right??
and i did try get into diagnostic turn wheel press brake pedal etc etc. but i just look like an idiot it doesnt seem to work.
well i feel a bit better knowing my problem isnt that bad!
power steering fluid, 4wd fluid in boot, (could be air bubbles in lines or just not enough) issues with wiring, issues with hicas computer on parcel shelf, issues with speedo/speedo cable. if worse comes to worse, id find a good qualified mechanic that knows GTR's. maybe even PM sydney kid
Angus Smart.
take your car to your closest or friendliest Nissan dealer and ask if they can fit up the "consult" to it and find out what is wrong. Hornsby Nissan is one Nissan dealer that should have the card for R32 GTR as they sold them new years ago. If you ask nicely they might find the problem for you for free and then you can head in the right direction as to what to change, replace or fix. Consult will check all the system outputs and inputs for you saving days of chasing your ass, and wires.
hope this helps.
Good luck.
how's our other thing going???
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
