im in the process of buying 2 amps for my 6x9's/splits and sub. came across this thing on ebay.
i think its a little out of my $500 budget
http://cgi.ebay.com.au/soundstream-class-a...1QQcmdZViewItem
would something like this really make that much of a difference considering for the same price you could deck out a whole car? WTF?
https://www.sau.com.au/forums/topic/172460-10000aus-ebay-amp/
well you can get mono block pre amps that cost over 30,000 each. then you also need a power amp, a source and speakers.
So that is fairly cheap.
Quality hi-fi ie nothing you will find at any standard retailer, costs a lot but is worth it.
My dad has spend at least 30,00 on our hi-fi and it consists of 2 speakers, an amp, and a cd player.
they look sweet... but cost price is about $2500 not retail it retails $8000 .. was going to get one but to much bling for me..
And didnt wanna make dr doof doof upset :)
btw that amp is not worth 10g thats a picaso neways which is old and is look orintated vrs sound output .. but the soundstream im talkin bout is big boom boom forgot its name but its chrome and a meter long
Edited by DECIM8
"soundstream class a picasso (CHEAT AMP) rated at 25 watts RMS * 4 at 12 volt at 4 ohms one of the worlds best sound stage amps"
can you explain why this is worth 10k FRX? i always love learning new things :)
firstly, i dont think it's worth 10k at all. in my other post i stated these used to retail brand new for arounf $2500.
$10000 is ridiculous for this amp.
The main reason why people would have bought this amp is that is massively under rated.
at 4 ohm it is 25rms x 4. At 1 ohm lets say 125rms x 4.
Back in the old days people used to buy amps with a small power rating that would load up, this was done for SQ competitions where you had to fit into a power class. Power classes were determined on the rated rms power at 4 ohms. But if you could have an amp where if you wired it up a certain way you got more power then you had the advantage.
At one stage soundstream produced an amp that was 2 x .5wrms. Yep half a watt per channel at 4 ohm. But, load it to 1/4 ohm and it would run about 600 rms. Sure the amps got hot, sure it shortened their life. But it also made some tech head wankers able to say there car was less than 3 watts rms and could produce 150 db+.
Buy todays standards of D-class amps this is out dated.
If anyone was to buy it they would only get it because it is old skool soundstream, not the new stuff that is crap.
Couldnt have put it better myself
A few years ago I had a listen to an awesome hi-fi system at a store. It was amazing (I heard instruments in some songs on a CD I took with me that I'd never heard before), but the setup cost about as much as my car.
It is quite amazing isn't it. Being able to pinpoint individual instruments around you, and if it's setup correctly (espcially with no rear speakers, which are useless in music) it's amazing how you can certain certain instuments around the room coming from different places.
I used to own a Marantz setup. I like my music and so I didn't want to buy some shitty Japanese mini system, but at the same time I couldn't (and wouldn't want to) spend the big dollars. I just tried that rig out to see if it was that good.
I'd still rather spend the $50,000 that setup cost on a car. And that setup wasn't even using the top-of-the-line components offered by the store.
even though marantz is good, it is not real hi-fi stuff. Some stuff is just on a completely different level, Mind you dad did have a chinese made SACD player for a while. It used a sony transport and DAC and was really good till it died. (dodgy sony parts) and it was a cheap SACD player. But hearing a reference sony sacd player is amazing as well.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
