Hey Guys,
I'm doing a CA conversion into my Datsun 1200 sedan hoping to build for around 220-240rwkw.
I've got r31 struts with coil ova kit and want to put some decent brakes for the street/track.
I've found some r32 GTR calipers/pads/rotors for a decent price. I assume they are 296mm rotors, but I'm just waiting for a comfirmation PM from the guy.
My problem is I dont want to run any bigger than 15" rims. I know for sure that the 280mm 32 GTS-t rotors fit under the 15's but I'm not sure bout the 296mm rotors?
Can any one help me? I have a set of 15" Blue bird TRX rims and alo a set of r31 silo 15's.
I would consider some r32/z32 4 spot 280mm brakes, for a decent price! If any one is upgrading.
Cheers,
Kym
https://www.sau.com.au/forums/topic/172643-gtr-296mm-brakes-on-datsun-1200/
don't know....the gtr had 16" rims over the 296 rotors but the clearance to the caliper is probably the real issue.
did the 33 gtst have 15" wheels standard? they fit over same sized brakes
wont fit over bluebird rims know that for sure have tried it myself on a 1600 with r33 gtst brakes and a 296 rotor, there is only 4mm between the caliper and the rim on a r32 gtr rim which is 16"!
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
