help needed front breaks make screach noise told need plates for them can annyone help im in vic will pay to buy and for sumone to instal them
screchers when put foot on breaks and hand break on its bad turn to manny heads my way help 0438 504509 [email protected] if annyone can help our nows annyone let me no needed bad
I think he's refferring to the backing plates that go on the back of the pads? I got new pads the other day and they squeal like all buggery, the mechanic said he can get some in from japan that would cost about $60 or so. Which reminds me I gotta call him and find out if they've arrived yet.
Cheers
  • 1 month later...
i TOLD HIM WHAT TO GET SQUEELER PLATES OFF THE BREAKING SYSTEM THEY ARE A THIN METAL PLATE WITH A EDGE IN THEM WHICH TAKE UP ANY VIBRATION FROM THE PADS AND BREAK THIS IS WHY IT MAKES SQUEELING NOISE...
HAD SPECILISED CLUTCH AND BREAK PLACE TO PUT A NEW HEAVY DUTY EXCEEDY CLUTCH AND BREAK PADS IN MY OLD CAR.....
GET THESE AND BOOK IT IN TO GEELONG CLUTCH AND BREAK SPECIALIST THEY WILL FIX IT STRAIGHT AWAY.
Hi dude. Please don't use caps. It is hard to read and implies that you're yelling.
The 'squeeler plates' are called shims. You can buy Anti-Squeal Paste to help keep your brakes quiet. Works a treat.
And to all fellow SAUers, the things that make your car slow down are 'brakes'. If a plate falls onto the kitchen floor, it 'breaks'.
Mark
Amen!
And where would we find such items? I think i'd like to give this a go. Sometimes mine squeal badly, sometimes they don't make a damn sound! =-/
Double Amen!
Heya Steve.
I use CRC Anti-Squeal Paste. It's orange goo in a bottle with a nozzle like you'd see on a tube of silicone. I found it at Auto-One in the same place you find CRC Brakekleen, CRC Carbycleaner, etc. Just keep an eye out for a small orange bottle. Slap it everywhere you like ;) But the best place is between the pad and the shim. It's super sticky and doesn't wash off clothing. It's about $10 or $15 I think.
I guess it just stops any noise caused by the shim vibrating against the pad - ie. squealing. It made my (otherwise universally noisy) RB74 pads completely silent.
That anti-squeal paste is good stuff and works a treat if you have shims or backing plates on your brake pads. A few other things to consider are that alot of brake pads have an audible warning built in to let you know when the pads are getting low. This usually consists of a piece of metal that rubs on the disc rotor when the pads are low. This can sometimes be bent during installation and cause it to prematurely rub on the rotor causing an audible sqeal. Another thing to consider is the high copper/metal content in the pad which will also cause squealing.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
