hi,
It could... but the best way to fix it is to incoperate your MAF sensor into your intercooling pipes, this way the computer only reads air the engine is getting....
+ it looks better than having it on the air filter...
Thats the way i'm going
hey guys i just bought a Blitz BOV and im wondering weather the power fc can tune it from crappy rev droping?
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3179511
if you put the afm in the cooler pipes wouldn't you have to put it after the bov so that it doesn't register heaps more air? if you have the bov after it, everytime you lift off and the bov opens the afm is going to register all that air passing it as going into the motor so dump heaps of fuel in (which is what happens with the afm in it's stock position. but if you have it right up against the throttle body then it is only double reading the air in a few inches of piping rather than a metre or 2 of air.
btw i am talking about on normal driving and backing off when you go to slow down, not when you are accelerating and changing gears fast.
but i also know plenty of people with r33's running atmo bov that don't have stalling issues. i was talking to a guy a few months back that has had 3 skylines, all with stock ecu and atmo bovs that had never heard of the problem (wasn't a forum user). keeping good spark plugs in them helps get rid of most of the stalling issue. i had the stalling issue with my stock bov.
also the emanage ultimate has a feature in it to help with the stalling issue.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3180844
yeah this forum seems to have real issues with atmosphere BOV's im not sure if it is becuase the tuners are shit or if the guys just dont fit em right in the first place, personally i never have, or never will use them for various reasons but plenty of the cars i inherit to tune do and honestly 5mins in the right spots on the map stops stalling altogether.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181200
People have issues as they all run stock management and expect a change to the system to work normally.
Either way, i wouldnt use ATMO either.
hmm, it cant work normally
I ran 3 different times on atmo bov on my r33 (hks, blitz and apexi) on stock ecu and HAD NO ISSUE with stalling, rev dropping etc
yes the car did run richer but it drove fine e.g dont stall on me
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181645
Screw atmo's.
Whhhhy do people still use them, they're past the point of being 'cool', no performance gains, defect target, cause idle issues and sound so try hard.
lol sounds like you got no idea.
Why would i ran my stock r33 bov when it leaks? i had issue with it on my stock turbo, why would i then put it on with my hks turbo running 16psi and over 350hp?
meh.....
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181646
look if you are desperate to fix it
read the pfc faq in my signature
learn how to edit the ign and inj maps
do a map tracer
replicate the stalling
find out what cells it hits when it stalls
and adjust them
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181806
meh.....
It sounds like you're uneducated 'Why would i ran my stock r33 bov when it leaks?'.
I'm running a bit less power than you (248rwkW) and I have had no issues with my factory BOV leaking.
Again, how did you know it was leaking or are just saying that because it doesn't make fully sic sounds.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181817
Its mainly based on your driving style.
I bet i could get it to stall easily, and at the same time, i could also keep it form stalling at all.
I went through it all on my own car.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181900
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
