hi,
It could... but the best way to fix it is to incoperate your MAF sensor into your intercooling pipes, this way the computer only reads air the engine is getting....
+ it looks better than having it on the air filter...
Thats the way i'm going
hey guys i just bought a Blitz BOV and im wondering weather the power fc can tune it from crappy rev droping?
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3179511
if you put the afm in the cooler pipes wouldn't you have to put it after the bov so that it doesn't register heaps more air? if you have the bov after it, everytime you lift off and the bov opens the afm is going to register all that air passing it as going into the motor so dump heaps of fuel in (which is what happens with the afm in it's stock position. but if you have it right up against the throttle body then it is only double reading the air in a few inches of piping rather than a metre or 2 of air.
btw i am talking about on normal driving and backing off when you go to slow down, not when you are accelerating and changing gears fast.
but i also know plenty of people with r33's running atmo bov that don't have stalling issues. i was talking to a guy a few months back that has had 3 skylines, all with stock ecu and atmo bovs that had never heard of the problem (wasn't a forum user). keeping good spark plugs in them helps get rid of most of the stalling issue. i had the stalling issue with my stock bov.
also the emanage ultimate has a feature in it to help with the stalling issue.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3180844
yeah this forum seems to have real issues with atmosphere BOV's im not sure if it is becuase the tuners are shit or if the guys just dont fit em right in the first place, personally i never have, or never will use them for various reasons but plenty of the cars i inherit to tune do and honestly 5mins in the right spots on the map stops stalling altogether.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181200
People have issues as they all run stock management and expect a change to the system to work normally.
Either way, i wouldnt use ATMO either.
hmm, it cant work normally
I ran 3 different times on atmo bov on my r33 (hks, blitz and apexi) on stock ecu and HAD NO ISSUE with stalling, rev dropping etc
yes the car did run richer but it drove fine e.g dont stall on me
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181645
Screw atmo's.
Whhhhy do people still use them, they're past the point of being 'cool', no performance gains, defect target, cause idle issues and sound so try hard.
lol sounds like you got no idea.
Why would i ran my stock r33 bov when it leaks? i had issue with it on my stock turbo, why would i then put it on with my hks turbo running 16psi and over 350hp?
meh.....
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181646
look if you are desperate to fix it
read the pfc faq in my signature
learn how to edit the ign and inj maps
do a map tracer
replicate the stalling
find out what cells it hits when it stalls
and adjust them
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181806
meh.....
It sounds like you're uneducated 'Why would i ran my stock r33 bov when it leaks?'.
I'm running a bit less power than you (248rwkW) and I have had no issues with my factory BOV leaking.
Again, how did you know it was leaking or are just saying that because it doesn't make fully sic sounds.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181817
Its mainly based on your driving style.
I bet i could get it to stall easily, and at the same time, i could also keep it form stalling at all.
I went through it all on my own car.
https://www.sau.com.au/forums/topic/172830-blitz-atmo-bov/#findComment-3181900
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
