ahh well at least its in a nissan box not an ntk one. how much did they rape you for that?
there are aftermarket ones with the correct plugs that are direct plug in replacements.
:) its say NGK on the actual sensor...........got it for $168 something with GST, I asked here several times if those NTK or Falcon ones gona be ok for my GTS4 non-turbo, the answer was yes, when i calld NGK directly about this, they advised me it wont be 100% accurate so asked to get original one ;) was paranoid about getting NTK after that
well I think I should have gone for NTK one tho (like$70 i think),,, oooh well
Note- got a OEM oil filter from NIssan while I was there, well they are not really genuine I guess, its made in Thailand.............I love stuff from Japan :)
Hey all. Just wondering if there is a part number for the tacho modual in a R33gtst series 1 1995 dash cluster. I want to replace the tacho unit in my cluster. Trying to work out if cheaper to buy new modual part (which i doubt), or just buy a second hand cluster n mix n match parts?
Can you attually just buy the tacho gauge?
part No# 24825 21u01. tacho meter only
hey guys. Need help with part numbers.
I have checked everywhere in nissan fast i can think of and havent had any luck.
Its the metal thing covered in plastic that goes on the doors just below where the window starts (see picture....the thing circled in yellow)
For 1990 r32 gtst
vin HCR32064384
Need the part number for each side.
cheers guys
looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
there is another part 80834-04U00 (RH) and 80835-04U00 (LH) "weatherstrip-front door inside". I think that is between the trim and the window though.
Looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
Thats the one. Awesome work Duncan....cant believe i missed it :(
i know this will be hard to find i would imagine but im after the part no. for a brake master cylinder from a wgnc34 autech 260rs stagea series 1 if possible (i think s1, and s2 is the same)?
i have 34 brembos on the stagea and need a brake booster to suit but i found out 33gtr and 34gtr use different masters i cant see why if they are the same brakes? hopefully the autech one will be the correct one.
thanks
If you have the r34 brembos fitted, wouldnt you be able to use the r34 brake master cylinder? im havin a little difficulty with fast so i cant check right now but im workin on it now. somebody else out there with fast might be able to post up the number before i get around to it.
"it would be easier and cheaper to get after market 1s. google r34 eyelids or use the search button at the top here."
tried the search and majority of em are DIY or from carmate. AFAIK, aftermarket ones are approx 120ish after paiting whereas the nismo ones are around150++. Would rather get nismo in this case
Do you know where can we get nismo eyelids?
thanks mate, i am just wanting to make sure the brake lines all line up with the 34 master thats all, its rather expensive to get it wrong ($300 or so), i cant see why the 34 and 33 would be different?
When i can get fast working ill have a look for a part number. not promising that it will be there though. you could try calling a Nissan dealership and speaking with spare parts. They may be able to help you. If not, try searching yahoo japan auctions. there is several ways to buy from there including Slidewize performance I bought from Zac a few times. always delivered what ive bought. Theres other companies out there that can buy from the auctions on your behalf.
Yea expenses suck. There could be numerous master cylinders that will line up. Maybe best speaking with a mechanic. You might be able to find a cheaper alternative to the R34 1. Ill try to find the number when fast is working.
thanks
Sorry for the inconvenience but its been ages since ive used fast and i have actually never looked for stageas before. can you make it easier and supply me with a vin number? that saves me a lot of stuffing around
ive had a look but i haven't been able to find it. maybe someone else that has fast would be able to track it down.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
