Need parts numebr for
R34 Bayside Blue Eyelids
Cheers
Part No# F2410-AA010. but i would expect them to be quite dificult to get a hold of now. better off tring to get a colour like white (QM1 and just paint them in TV2)
i know this will be hard to find i would imagine but im after the part no. for a brake master cylinder from a wgnc34 autech 260rs stagea series 1 if possible (i think s1, and s2 is the same)?
i have 34 brembos on the stagea and need a brake booster to suit but i found out 33gtr and 34gtr use different masters i cant see why if they are the same brakes? hopefully the autech one will be the correct one.
thanks
would like a vin to confirm but fairly sure the part No# is 46010-0V600.
Your car is a 4WD with a RB26DETT correct? hence making it a AWC34
Hey All.
Does anyone know the part number for the FRONT and REAR tie rod ends for a R33 GTS-T 1995 S1. Mine are shot and the guy at nissan ere has NFI. If i get the part number for him then maybe i will get more joy out of the nissan dealership. I am also considering aftermarket parts too. anyone suggest a good option?
Any help appreciated. :rofl:
what an awesome thread - well done guys!!!
i am after the part number for the inner door moulds which sits on the inside of the door trim & wipes the inside of the passenger/drivers window (for r32gtr)...i found this so want to know if this is correct:
R32INMOULDLHS-8083504U00
R32INMOULDRHS-8083404U00
Hi there,
I need the part numbers for the front plastic inner guards on a 96 R33 GTS-T. The ones that I need wrap around underneath the front bumper bar and intercooler. I need numbers for both sides please.
Thanks, Pete.
Part NO. 63842 15u000 RH
Part NO. 63843 15U000 LH
MARKO R1. SOUNDS GOOD TO ME I CAME UP WITH THE SAME NUMBERS
Hey All.
Any help appreciated. :thumbsup:
PART NO. 48520 15U26 LHF & RHF
PART NO. 55725 0C800 RHR & LHR
Hi,
I need the part number for the front centre mesh grill section between the headlights for a R34 GT-T, the NISMO version.
Thanks, Carey.
there are 6 different option need to know paint code. also year model an month to make sure
back again, unfortunately there is no paint code sticker on the car. so the only info i have is year model is 06/98 colour is white (r34 gt-t). hope that gives some clues .
Kind regards
Carey
Hi guys,
I search and look for the original partnr. of the shocks (front and rear) for a skyline r33 gtst from 1995.
Vin.nr. ECR33-055072
I hope that someone can help me with this. :nyaanyaa:
Regards Mindert
Edited by boro
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
