Hello. Here is a permanent solution to fixing those faded skyline headlights. One of my mates from tafe inspired the idea.
Pretty much I was sick of polishing my lights every 3 months after the plastic oxidized itself again.
Here is a pic of my car with the dull look headlights
If you are going to DIY this I would recommend some previous spray painting experience and also good safety gear like a respirator and good ventilation (preferably a booth of some sort). If not take the lights to a paint shop, I can’t see it would be very pricey to do a small job like this.
Here are the materials I used
Plastic Primer
Antistatic plastic cleaner
2 pak clear
2 pak hardner
2 pak reducer
2" masking tape
1 bucket of water
Sponge
truckwash
1000 grit wet and dry sandpaper
Tools used
3.5hp air compressor
1.4mm spray gun
Screwdriver and socket set
1 - Ok first of all u will need to remove the grill (held on by a few clips) then remove the headlights (few bolts on the rad support and 2 small screws underneath)
2 - place the headlights on something stable, fill a bucket with water (and a dash of truckwash if u like), soak a sponge in the water and run it over the headlight plastic while sanding with 1000 grit paper until the whole light is a fine haze of scratches.
3 - Dry the headlights off, use a clean rag and wipe over with the plastic cleaner.
4 - Mask around the outline of the headlight (not totally necessary, just me being fussy) use an airblower to remove any dust from the lights.
5 - Pour about 100ml plastic primer into spray gun and place a light coat over the lights (allow a minute or 2 to dry)
6 - Mix up the clear. the one I used was 4 parts clear, 1 part hardner and about 10% thinner. Now spray a light coat over the lights (just enough to make the lights look clear)
Allow a couple of minutes for coat 1 to tack off and put a final coat on (so the finish looks nice and smooth)
Give it about a day to dry hard, fit them back up to the car, and never have to polish up dull lights again :thumbsup:
Edited by Sambo33
https://www.sau.com.au/forums/topic/173132-fix-your-faded-skyline-lights/
I'd like to see how they go after a few months in the sun.
I thought the plastic broke down with UV light, which caused the hazyness. If that's the case, a clear coat of paint may not stop the UV from reaching the plastic, and may still breakdown the polymers...
Trav33 ive had this on my car for about 1 year now, no more dull headlights :thumbsup:
thanks for the comments guys!
i think my lights may have been worse than most, i previously used farecla medium grade cutting compound on a machine buff on my lights. After about 2-3 months they were yellow and dull again.
DrewII - i get some moisture inside my lights sometimes when that car gets wet, but it evaporates away. the yellowey dull look is only on the outside of the plastic.
I guess to turn the lights yellow you need oxygen too .. this fix restricts oxygen from the plastic so the yellowing does not occour?
Im confused how you got from a dull faded smoked light to such a clear one? U just sprayed over it with clear and it make the cloudyness go away?
How does that even work? Did you not cut back the plastic to remove bemishes?
Edited by DECIM8
yeah mate, the pics of the headlights on the stands where they look all dull.. those are fine sandpaper scratches. wet-sanding the lights cleans all the tarnish off, when i was rubbing them down i could see all the yellowey stuff running off them.
the stock plastic cant stand up to the effects of weathering, the 2k clear is essentially a type of plastic. so im reinforcing the plastic.
ive used this particular clear on some of my cars before and it can take weathering fine, no drop in gloss, no yellowing.
hope that makes a bit more sense :thumbsup:
you should run a headlight exchange business!!
i would love to do this, but am afflicted with accute laziness and lack of a compressor :thumbsup:
thats not a bad idea :cheers:
i would do it if i had a better facility and a bit more time.
Excellent cheers and does it scatter light at all or disipates light as original?
nope, no different. the clear film build would be similar thickness to an a4 sheet of paper.
Nismo_God - No worries :thumbsup: my method was a bit thorough, but it can be done easier than that.
  • 2 years later...
cool man glad you tried this out ive thought about it before but never got around to it.
i just p1500 then p2000 mine and polish them up with farecla g3 and they have been clear for about 4 months now but looks like a clearcoat would be a permanent solution. anyone in adelaide wants this done hit me up lol
Edited by TWINS33
  • 8 months later...
hey man i kno this thread is dead but does the offer still stand about the polish and clear in lonnie? i would pm ya but im a n00b with less than 10 posts.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
