Hey guys. I have a hks mushroom pod and the filter foam need replacing desperately. Is it worth paying $50 for more foam or I can get apexi power intake pod for $85 new. I know the apexi is the dry type filter but ive heard nothing but good things about the hks pods. Whats best??
https://www.sau.com.au/forums/topic/173306-which-pod-filter/
i use a k&n pod filter. no dramas so far. fantastic local stuff :P
get the cleaner kit for it and do it every 10,000k's
Yeah ive had k n N filters before too, they are good. Just thinking maybe the dry type shit now that everyone goes on about the oil killing afm's??
K&N Pod. They don't foul your afm with oil either. They only do if you get over enthusiastic when your re-oiling. Even then if you do over oil just spray electrical contact cleaner over the afm element after you've taken the car for a drive. (allows the larger portions of oil to be ingested, leaving the rest in the filter.)
i had a KN now a HKS mushy...
KN louder then HKS
HKS dry KN oiled
HKS fits into smaller places where KN cant (eg my engine bay)
KN much cheaper (can get them for under $50 at autobarn sales)
If i had to pick another besides these two, wouldnt mind checking out the Blitz pod...APEXI no way, some say its good some say its absolute crap...wouldnt want to spend $200 on something that MIGHT be good.
But yeh i cant decide between HKS or KN
Ive got an HKS mushroom on my car.... give it a clean every few months... sounds good, looks good, lots of flow...
borrowed an Apexi Power intake one and put it on the car.... it was so farken quiet that it felt like i was almost driving a non turbo! plus the car didnt feel as quick!
hks one back on the next day!
The stock air box with K&N panel filter sounds so much more classy and refined. You can also hear the turbo spool rather than the awful loud sucking noises you get with a pod
my thoughts exatly. nothing sweeter than the spool. even though im on a stock turbo
Didnt feel as quick cause you couldnt hear the loud sound. from my experience the apexi is quite loud. Personally stock box with hi flow filter is good. no heatsoak and car sounds good enough. didnt by a turbo because of the sound it makes.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
