It's the ebay one isn't it. LOL.
Well being designed for a 4L engine and it's characteristics, it would propably come on boost fairly late, but once on make good power, i'd go out on a whim an say 270rwKs or so at 17psi.
I am sure i have heard that someone has done this already.
lol yer
They are pretty laggy on the 2.5ltr and tend to come on really smooth; they feel like an N/A with lots of top end.
Considered a GT30 .82 or .63 IW from slide? Well priced.
Then you need to factor in the additional cost of a split dump $380, water/oil lines/banjo's $150 and inlet pipe which is easy if you have a pod $50 for a 90degree bend of either 3" or 4" + some silicon.
easton runs one on his r31. she cracks. its running external gate tho. they cant hold boost for shit with there internal
Its quite the opposite when running them with the std int gate. They tend to boost creep; on the 4ltrs at least; I don't believe the larger 1.06 + gt35r turbine wheel will creep on a 2.5ltr.
what we talking about when the boost kicks in?
  • 4 months later...
Yeah I'm running one of these on my 33 and its not too shabby. Was already on ther when i bought it. Mods
HKS cooler and Exhaust
BOV
Stock injectors :-(
Microtech lt-12
Bosch 044
Tuned at 343rhwp at 17psi.... is a tiny but laggy but am hoping an electronic boost controller might help. Holds boost sweet on internal gate and has been run at 19psi fine. Just doesn't hit full boost till about 4000rpm.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
