Need to get my stock 32 turbo off to replace with a similarly sized 33 hi-flow. Is it possible to get the turbo on & off without removing the manifold or is this a must? Want to know if I need a manifold gasket because this will be getting done at home over a weeend. Want everything I need prior to removing anything. Yhank you
https://www.sau.com.au/forums/topic/173881-removing-32gtst-turbo/
You can easily take off the turbo without manifold coming off.
Its 4 bolts, couple lines off, and turbo is out.
I would however advise if your going to do it... to change manifold gasket. But REMEMBER... you WILL break manifold studs. So be prepared to replay/drill out a few.
If you dont know how, then i'd probably just pay someone.
Easier :(
I replaced all the manifold studs about 6 months ago while fitting a dump pipe & replaced the gasket then so dont want to do it again unnecessarily. Removed turbo & manifold as a whole so wasn't sure about splitting them in the car. Mechanic by trade mate, so replacing studs is no problem... Just dont get to work on Skylines etc. quite as much as I would like... Thanks for your help
If you've done the studs, then no worries.
No need to change them or the gasket now.
Just swap out the turbo.
4 manifold--turbo flange bolts
Oil/water lines
Oil return line
And it should pop out if you remove all the surrounding piping.
Turbo off with manifold on poses no real problem. Also i'd replace the banjo bolt washers while your at it.
Its pretty straight forward, much easier than taking manifold out as a whole.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
