  • 7 months later...
  • Replies 140
Hey guys, anyone in sydney want to or know someone who will install the Xenon light on mine for a fee? i just dont have the time or knowledge to do it... thanks :D
+1 to that. Also want them and wouldn't mind a recommendation based on experience.
Was just about to reconnect my xenons together when it unfortunately looks as tho they've cut the wires to close to the loom, my problem is i'm not too electrically minded and the only way i see to re connect them is to splice them (wires being too short i can't) is there any way I can get some sort of spacer to crimp on the ends so it gives me a bit more room.
Much appreciated if anyone can help cos I really want to get these going.
  • 1 month later...
I am a bit of a noob in lights... I want to get HIDs from the group buy at http://www.skylinesaustralia.com/forums/Hi...y2-t242766.html
Now, question I've been asked, is what type of a bulb I have. Is it correct to say it is H4?
Do I need to specify anything else so it can be fitted into the V35? Or it wouldn't work? (I do want to keep my fog lights etc as it is)
Any help in helping a lights noob would be appreciated :D
I don't think so. I am pretty sure the guy who complied it took it out, because he resells them to other cars. So I'll need an HID ballast too I gather?
I am thinking low beam (the normal driving lights). I don't really use high beam much. I just want my car to have a more prestigious look when the lights are on.
If your headlight is 2003 model, Low beam will be D2S, High beam/fog will be H4.
Cheers
Frank
Ah, cool. So I have to get a D2R bulb with an HID ballast? Someone mentioned to me that it is H1 bulb... That's not right, right? Everyone refers on these forums to D2R. How come are fogs and high beams the same? They are different lights, thought would be different bulbs also... And also, I've read that people started to have their fogs turn on at the same time as parkers etc - that's due to bad wiring right? Not because of the HID kit?
Edited by russky
For 2003, the HIDis D2R, FOG and High beam is same buld which is H4--you know that H4 is a double light, right?
For 2006, The HID is D2S, Fog is H1, High beam stay with HID as be-xion.
Fog/ Driver light has it own wire. So if it on together with parkers, will be a wrong wire.
franks
  • 3 weeks later...
I need help, I got myself the original HID Ignitor (which is the cable from the ballast to the D2R bulb, Mine was cut off), when I was converting it back from H1 to HID. I accidentally plug in reverse polarity to the Original Ballast on my right side of my HID, I believe something blew, but using my left side, I did a check on the ballast & Bulb, it worked (Lucky me). Anyone knows where is the fuse for the HID or any other remedies?
wish you had brought them in when I was down there last. I had the front off the car to do the cruise control. drop the front off when you do it and watch the drivers light as the cruise unit is below it.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
