I have a really n00b question.
If i drive 80% of the time off boost (<3000rpm), will lowering my boost help with fuel economy?
imo, i say no. but then again, i'm not actually sure.
Can anyone enlighten me on it?
Thanks!
Edited by dan.1337
https://www.sau.com.au/forums/topic/174123-will-lowering-my-boost-help/
I'm just thinking that when I'm off boost, it drives like a normal 2L engine (rb20) and when on boost, that's when the air + fuel etc come in.
Is that true? Or when I'm running below 3000rpm the turbo is still spinning and pushing air into my engine?
If anything, when I'm giving it stick it's between 4000-6000rpm but i'm not sure if I'm on full boost during that time as I'm too busy watching where I'm going and not my boost guage.
I was told that my dropping my boost pressure below 10psi, I'll get better fuel economy. Right now, i'm running 16pounds.
If it helps, here are my mods:
rb20det
HKS 2535
550cc injectors
Link ECU
Bosch 040
cooler, pod, 3" full exhaust.
i'm currently getting exactly 300km to the tank.
Edited by dan.1337
What? No. If your not boosting then the turbo is not pushing air into your motor. It depends how you treat the throttle whether you get good or bad economy.
Thats what I thought. If I'm not really pushing air into my motor (<0 on boost guage), then lowering my boost will not help. Almost all my shifts are below 3000rpm unless I need to overtake those new trams. Damn they're fast.
hmmmmmmmmm
you want better economy but you have a bigger fuel pump, bigger injectors and a after market computer, all of which help get more fuel through, then u ask if u wind the boost down will you get better economy even tho your not boosting. sorry to say but u don't buy a skyline to get fuel ecenomy of a excel
hey i get really good economy outta 700cc inj bout 400-500km and thats rb25 gt3040, q45afm etc.
its just a crap tune get it retuned. also what injectors are they cause if there rx7 ones then they uise heaps of fuel. Also turnin down the boost wont help if you drive off boost as its not like your driving on full boost all the time.
i'm not looking for the economy of a prius or excel. definitely didn't buy the car to save the world. just thought that 300km to a tank is a bit low, i'd even be happy with between 350-400 which isn't all that far away from what i'm getting now. just unsure why i can't sqeeze out that extra 50-100km esp when i'm driving off boost a lot of the time.
my injectors are Denso 550cc. direct drop in for the engine so i don't think they're from an rx7 (unless i'm wrong).
my car was tuned recently. it used to run extremely rich (almost on the verge of flooding the engine) and everything on the inside has been blacked out with carbon deposits. i was told by my tuner that over time the crap will be spat out of the system and economy should improve again. i don't think he's a crap tuner as one of my friends who has had his tuned by the same guy with almost the same mods gets 400 to the tank each time.
i might go thru a couple more tanks of petrol first and see if things get better. each time i drive little black spots of carbon which have been softened by the exhaust condensation is spat out (quite a lot of it) - so i know that something is heading in the right direction.
will be holding off on the ebc for a little while.
thanks for the all the insight tho!
Maybe get a new oxygen sensor, and if that doesn't help get the ecu retuned. Get the workshop to spend a decent amount of time on the lower load points etc to improve your economy.
i suspect the link doesnt do closed loop so an oxygen sensor wont do squat
you should confirm with your tuner if it supports closed loop 02 feedback or not
if it doesnt get it tuned for light cruise / low load or change ecu's
if it does, then get the 02 sensor checked/changed and or get the afrs for light cruise trimmed
also drive normally, dont back on/off throttle constantly to raise boost and make boost nosies
another idea is your get your gf or mum / dad to drive your car, see what economy they get in it - i bet its much better than what you get
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
