BLoody hell the weather BETTER BE GOOD!..
Over the weekend:
-Stripped Passenger + Rear Seats
-Removed Passenger + Rear SPeakers
-Removed Passenger side door trim
-Removed from front Strut Brace
-Swapped my Drag tyres on
Looking forward to see if it makes jack all difference with all that effort and make use of the weighing bridge at WSID
i want a SUB 12.5 damnit!!
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3198682
HAhah i probably could remove the boot but i dunno how i'm gonna drive my car from HOME to WSID (45minute+ drive) without getting pulled over.
hmmm 30kg.. ey.. we'll see if its worth the hassle.
BENM: I'll remove the drivers side and put a milk crate if you drive it down for me :)
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3199200
what do u need to do to get out on the track for a day ?
just rock up with ur car pay how ever much ohh helmet n clothes get ur car checked to see if its okay
then wat do u just go on ??
You need your rego papers too.
I'm going to give this one a miss. And head out in two weeks. I was going to go next week, but SOO 3 is on.
ap
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3200523
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
