BLoody hell the weather BETTER BE GOOD!..
Over the weekend:
-Stripped Passenger + Rear Seats
-Removed Passenger + Rear SPeakers
-Removed Passenger side door trim
-Removed from front Strut Brace
-Swapped my Drag tyres on
Looking forward to see if it makes jack all difference with all that effort and make use of the weighing bridge at WSID
i want a SUB 12.5 damnit!!
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3198682
HAhah i probably could remove the boot but i dunno how i'm gonna drive my car from HOME to WSID (45minute+ drive) without getting pulled over.
hmmm 30kg.. ey.. we'll see if its worth the hassle.
BENM: I'll remove the drivers side and put a milk crate if you drive it down for me :)
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3199200
what do u need to do to get out on the track for a day ?
just rock up with ur car pay how ever much ohh helmet n clothes get ur car checked to see if its okay
then wat do u just go on ??
You need your rego papers too.
I'm going to give this one a miss. And head out in two weeks. I was going to go next week, but SOO 3 is on.
ap
https://www.sau.com.au/forums/topic/174129-wsid-again/#findComment-3200523
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
