Yeah i was going to say the same, a bit on the rich side, orange is definalty from the octane booster. Number 1 and 6 are a bit ritchen then most, well possibly it's the pics. Timming is close, but i was under the impresion that the top of electrode burn had to be as close to the end of the. quote
"Ideally, you want this blue line to be just below where the ground strap makes the sharp bend and above the weld. If you advance the ignition too far the blue will disappear off the strap and the strap will pick up rainbow colors (blues and greens)."
http://www.dragstuff.com/techarticles/read...park-plugs.html
Anyway looks good either way
Hey,
first, I don't read plugs for mixture on the car because I have a wideband to do that
and the method I use on the bike is not a Good Thing for a turbo car :mrt:
Second, I'm no plug-reading expert but I have done it a few times on my bike
with expert help. On the bike, I have to run at the load and RPM I want to check,
then hit the kill switch, coast to a stop and pull a plug. If I idle to a stop I can't read
the plug because they're basically black like yours.
Did you chop the ignition during/straight after a full-load run then pull the plugs?
Because that line of what looks like fuel right near the electrode looks to me like
the car was idled for at least 20 seconds before the plugs were pulled. You might
need to try it again...
Hope this helps :)
Regards,
Saliya
Looks like your have a cracked insulator - so you may have a detonation issue however its hard to tell if there is any aluminium spheodites on the plugs as there is so much octane addtives. Not sure how poeple are saying that its rich as once the insulator and plug is that lead fouled the insulator doesn't get enough heat into it to burn off the deposits so the plug never cleans itself.
Typically pink orangy coloured plugs indicate coolant burning.
that is definately octane booster not coolant. its too hard to read plugs without knowing the condition it was running before switch off. from a quick glance i would think about 7's. Other than that a wide band is a far safer quicker tool.
Its definitely menstruating, wait a week or so and try again!
One question---------did you do a plug chop? or was this after you drove home and parked it in the driveway/shed?
Hi what are the brand of mags you are running on your vehicle?
I just drove it normally so yeah it probably idled a bit before it was turned off. I didn't realise the condition was dependent on how it was driven just before stopping it.
Yes I have used octane booster a few times.
I have also had some detonation. Lucky my forged pistons seem to be holding up ok.
You read the plugs for the rev range you want to assess burn for.
ie You drive at 4000rpm and do a chop, then you do 6000 and do a chop etc etc and its best done under normal load etc no revving in the driveway, either a dyno or a racetrack etc.
Or if your only interested in one bandwidth then do a chop on it only.
Sorry Saliya, just saw your reply, and you are correct.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
