okay, well while working on my other car the other day, i parked my skyline outside in the rain, and the indicator under the two red lights filled with water,
luckily nothing shorted out or anything like that but i decided to take the tail lights out and have a squizzy at them (aswell as empty the water :(
10 mins later the tail lights were in the oven softening up the glue and soon after they were apart,
basically i think i can make my tail lights look very similar if not identical to the ones as pictured,
in the picture you can see the red lenses have been removed from the lights, i did that and underneath is clear lights, now if i get sum thing like even vht nightshade spray and spray the inside of the lights under neath it would look very similar to the ones pictured
a bit hard to explain but will report back and post pics in the next day or so :D
sam
  • Replies 61
Posted Images
luckily nothing shorted out or anything like that but i decided to take the tail lights out and have a squizzy at them (aswell as empty the water :w00t:
a bit hard to explain but will report back and post pics in the next day or so :woot:
sam
Sam take a picture! also what temp you have the oven on to cook your lights?
sam
cant wait to see!
i will take some pics when i get home :woot:
um i think i put the oven on 200 :w00t:
they were in there for no more than 4-5 mins after the oven had time to heat up
will get back to everyone soon ;)
sam
80 100 ish mark
it takes about 8 minutes to heat up
ALL you're trying to do is warm up the particles in the glue, this will make it go back to being tacky and maluable thus allowing the parts to become seperate
200 degrees is just stupid, you don't use a shotgun to change the TV chanel, same as you don't use 200degrees of heat to warm up sealant glue!
i dont use an air rifle to change the tv channel wither... i use a remote...
all im saying is that 200 ambient heat for 5 minutes worked for me... but my lights dont fit in my oven with it being shut... forgot that...
so... what kind of gun do you change the channel with? :)
well yous can use 80, thats fine, i used 200 and nothing melted, came apart nicely :rofl:
still havnt finished, im using some black sealant because when you put the light cover back on there a gap were the red lense used to be between the cover and the other section of the light,
i will have to take some pictures tomorrow morning :worship: all the pics i take the flash on my camera totally f**ks it up cos its dodgy
ill write up a proper diy thingy later aswell :rofl:
so far im happy with the results :)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
