  • Replies 951
I'll be there. If you want to leave earlier I'd be keen to do that also. Sam, you need to come down Thursday morning. Too good of an opportunity to miss...
Sam/Chubbs - just remember "the GTR neva lose.....(did I misspell that right Snowy?)" The NSW champ this time will will be in a GTR (thought it might not be me). Your puny single turbos stand no chance....
In Chicago today and back in Sydney on Wed AM. Talk then.
Yeah im happy to leave earlier - i really dont care what time
As soon as we get there im going to have a BBQ :)
Ok, so is this right;
Group heading down thursday:
Anna (Msnismo)
Brad (Risking)
Jess (Sinful)
Sam (SAM916)
TJ (TJAndriesen)
Nick (Intune)
Steveo (N1GTR)
Shawn (Smoky)
Jen (Tripin)
Nigel (Tripin)
Wayne (DJBrave)
Kasey (Tinks)
Chris (Evil weevil)
Gorgie (Evil Weevil)
Kelly (Adorra)
Group heading down Friday:
You
Chris and gorgie
Jen and nigel
Wayne and Kasey
Doof
smoky (maybe)
......right?
By the end of this trip Caltex will love you.
Another reason i love my "job"
Me: So im going to be away for a while
Boss: Ok, where are you going this time?
Me: Victoria
Boss: Oh...right, whats down there?
Me: A car driving thing
Boss: Oh, that sounds cool. When do you get back?
Me: Sunday or monday or tuesday - see how it goes
Boss: No probs, just ring me when you are on your way back and let me know
Me: Easy
Boss: How are you getting there?
Me: Driving my Supra, it should use a decent amount of petrol
Boss: Yeah it sure will
So what do i get off work later that day? See the pic :)
Then you'll see the thread with "My Supra has a broken engine, because it was pinging off it's tits".
But wow Damm is that $400 of petrol vouchers! I had 100 $10 caltex vouchers at work before. Too bad wasnt mine.
Anna (Msnismo)
Brad (Risking)
Jess (Sinful)
Sam (SAM916)
TJ (TJAndriesen)
Nick (Intune)
Steveo (N1GTR)
Shawn (Smoky)
Jen (Tripin)
Nigel (Tripin)
Wayne (DJBrave)
Kasey (Tinks)
Chris (Evil weevil)
Kelly (Adorra)
You
Chris and gorgie
Jen and nigel
Wayne and Kasey
Doof
smoky (maybe)
......right?
mmmm given you have some people on both lists I'm thinking it's not right....
Do we want to start earlier?
What time?
Same meeting point as last time?
Steve, can you post up a map to the meeting point?
The Friday list is correct... + then add... myself, Kelly, Jess & Brad to the Friday not Thursday list!
And of course take out all the double ups on the Thursday one - which looks like its the total NSW peeps heading down!
So...
Whats the accomodation set up then for us?
You rock up and they are all under my name Jessica Hearne/SAU and we have Luxury Lake cabins 1, 2, 3!!! It was in your pms what cabins you ahve each been assigned too...If you are not happy with that you guys can swap between yourselves :)
What time?
i don't know what the exact plans and timing is for the thurs guys, what are you doing TJ? I'll just tag along with you.
So what happened to winton? No one doing it?
Im confused
You rock up and they are all under my name Jessica Hearne/SAU and we have Luxury Lake cabins 1, 2, 3!!! It was in your pms what cabins you ahve each been assigned too...If you are not happy with that you guys can swap between yourselves :action-smiley-069:
Havnt got pm
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
