Which do you think will be worth more? When your a pro whats an extra minute?
What difference does it make which would be worth more?
It's not like you can sell a stolen car and make as much money from it as if it were a legitimate sale...
If you steal a Skyline, you'd sell all the parts from it, and no-one would be wiser.
HEy dude there is a guy in your area that does alarms in clayton south on whitehorse rd really great guy n great on costs to as well deals with all audio and security his name is Daniel form Complete Options they deal with alot of Skylines and Imports he will hook u up good really good giv him a go ull b really happy
Hey Mate I know your trying to help but whitehorse rd is around near boxhill far away from clayton, got any contact details???
If you dont trust him dont get an alarm off him.
I wont.
Yes, makes it much more convinient. You must be a F*****n Idiot to think this guy would come steal your $15000 skyline when he works on M3's, AMG's jaguars etc.
He is Very professional. Anyone can steal your car, this guys profession is installing alarms, audio and visual. Not a professional thief.
Why would you put an aftermarket alarm into an M3/AMG/Jag?
Im trying to workout a deal with the SAU-Vic club. (so become a member mate)
$200 will get you a fully installed and insurance approved alarm :domokun:
With additional extra's to suit.
So decent security, at very affordable pricing. ;)
Any news on that ?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
