I remember ringing one of the guys in the yellow pages a few years ago. basically got a lecture as the guy seemed on his high horse for no reason and mentioned a few times that he polishes the "Rundle mall balls" and can do a show room polish that will clean with just petrol blah blah. I try stay away from knobbers like that...
If u have some time and patience u can do it yourself depending on what it its. U just need to use some wet/dry emery paper to take it gradually down to a fine polish, then if u can use a bench grinder setup with a polishing wheel, and use clay will make it a mirror.
Really depends on what u want done though (is it smooth and flat, or has lots of surfaces etc) and how well u want it polished or mirror....
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202188
Got most of my engine bay stuff polished through [boostworx] Shaun's guy. Also, currently getting some stuff chrome plated by Windsor Electroplaters in Windsor Gardens who also do polishing & are a bit pricey but, they were the closest.
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202231
If you are will to put in some elbow grease andz you can use metalsol
i think it is called or something similar to bring the shine back to your exhaust tip.
That would be Autosol, Works a treat too!!
I need to get my whole car deatailed and cut n polished, just want a pro to do it tho......
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202716
ahhh thanksssss, need the shiny exhaust tip for the rice factor
autobarn would stock them i guess
Hey Andy, try Meguiars NXT generation Metal Polysh. Bit expensive, but the lady at eliz autobarn lent me the store sample of theirs and its the best one i have ever used! Was good for the radiator panel, intercooler pipes and the exhaust tip!
As for the polishing Shaun, the best advice would be to try to do it yourself. What are you polishing?
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202957
I'll get you a number for Stan the polishing man, get stuff done through him at work. Just file out any major marks that you don't want, ie. casting marks and he will bring it up beautifully and for next to nothing.............
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3203187
I am polishing my intercooler and pipes now that everyone will be able to see them with the new bar in place and there will be lots of other stuff as i go along and bring the engine bay up to scratch.
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3203701
i use ultra gloss for body polishing i like comes up soooo shiny especially after using the paint cleaner as well that you can get in a dual pack...........
ohhhhhhhh metal polish...i read it wrong!! i got meguirers metal polish very good
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3206555
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
