  • Replies 108
So who here is going to dress up their skyline? I got some fooly sic plans for mine :( Gotta have some neons, paint jobs, chromies, stickers, and custom plates!
Pretty simple to do it on the cheap and easy guys... Glow sticks for "neons" @ about $1 each - they're single use for about 8 hours, but can't be turned off however there's no need for wires... Stickers can be printed out and stuck to the car via fridge magnet... Chromies would be hard but perhaps you can get some chrome coloured hub caps, and loud BOV's can be recorded, burnt to CD's and played back at random times in your cd players :-)
http://www.glowproductions.com.au/ ;)
Now guys, we all gotta do something to fit in with the theme... We all know it's probably going to be a crap movie, but that doesn't matter. I imagine most of you will be there for fun, so it should be even more fun if we all do the ricey thing. ;)
Same as on first page but updated 11/6/03
Friday 13/6/03 is the Date.
Venue wil be:
Greater Union Blacktown Drive-In
Address: Cricketers Arms Road
BLACKTOWN NSW 2148
Move will be a double feature!
Field 1
First movie starts at 7:30pm (8-Mile is on 5th to 11th June, not sure on the 13th)
2F2F Start time is 9:40pm
Cost $10. (No EFTPOS facilities)
BYO grog!
Attendees:
Majanal + Jody
Duncan and Kel (I assume you will be using the same car and only one spot?)
Driftn 180
B-Man with one other of the fairer sex
Carlo + Toshi
Ricky B
ndr + Mel (and Monty?)
fatz + Dom
mmmgtir
PuppaDuck
RXB05S (thanks for organising us the discount mate)
Kinks
elcano
RedGTST + g/f
Blitz
Airzone + A lot of people in his car.
Prank + Bec
Jimbo
Tex
Marty + Fiona
Jon (Stenno)
xzotik1 + one mate
= 21 cars... rice! (Might be 22 as Kel refuses to ride in a neon Skyzer!)
(are the bottom guys still cool with going to blacktown?)
Maybe's
a5h (probably)
Silver-Arrows
Tex
Croatian R33
HSVKLR
Benm
Knat
For Northsiders:
What about Nth Ryde Maccas ?? It's sort of more central than BK TH (which aint there anymore anyhoo)
For Eastsiders, & Westsiders, I have no idea - someone else who know a goos area can suggest that one.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
