  • Replies 108
So who here is going to dress up their skyline? I got some fooly sic plans for mine :( Gotta have some neons, paint jobs, chromies, stickers, and custom plates!
Pretty simple to do it on the cheap and easy guys... Glow sticks for "neons" @ about $1 each - they're single use for about 8 hours, but can't be turned off however there's no need for wires... Stickers can be printed out and stuck to the car via fridge magnet... Chromies would be hard but perhaps you can get some chrome coloured hub caps, and loud BOV's can be recorded, burnt to CD's and played back at random times in your cd players :-)
http://www.glowproductions.com.au/ ;)
Now guys, we all gotta do something to fit in with the theme... We all know it's probably going to be a crap movie, but that doesn't matter. I imagine most of you will be there for fun, so it should be even more fun if we all do the ricey thing. ;)
Same as on first page but updated 11/6/03
Friday 13/6/03 is the Date.
Venue wil be:
Greater Union Blacktown Drive-In
Address: Cricketers Arms Road
BLACKTOWN NSW 2148
Move will be a double feature!
Field 1
First movie starts at 7:30pm (8-Mile is on 5th to 11th June, not sure on the 13th)
2F2F Start time is 9:40pm
Cost $10. (No EFTPOS facilities)
BYO grog!
Attendees:
Majanal + Jody
Duncan and Kel (I assume you will be using the same car and only one spot?)
Driftn 180
B-Man with one other of the fairer sex
Carlo + Toshi
Ricky B
ndr + Mel (and Monty?)
fatz + Dom
mmmgtir
PuppaDuck
RXB05S (thanks for organising us the discount mate)
Kinks
elcano
RedGTST + g/f
Blitz
Airzone + A lot of people in his car.
Prank + Bec
Jimbo
Tex
Marty + Fiona
Jon (Stenno)
xzotik1 + one mate
= 21 cars... rice! (Might be 22 as Kel refuses to ride in a neon Skyzer!)
(are the bottom guys still cool with going to blacktown?)
Maybe's
a5h (probably)
Silver-Arrows
Tex
Croatian R33
HSVKLR
Benm
Knat
For Northsiders:
What about Nth Ryde Maccas ?? It's sort of more central than BK TH (which aint there anymore anyhoo)
For Eastsiders, & Westsiders, I have no idea - someone else who know a goos area can suggest that one.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
