Hey people, ive been doing alot of oil changes to my car in the past, and need to know how to correctly top it up....
I just bought a 5l castrol edge 0w40, and filter too, doing both at the same time....but need to know the best way to top it all up.
Usually i just loosen the filter, and the drain plug and let all the oil come out, then top it upin one hit....
but i was told to top up 4l first, then turn on car, then top rest up till the oil is at the high level on the dipstick....should i be topping up all 5l or no?
thanks in reply!
Put in about 4.5l. Start engine until the gauge registers pressure (5 - 10 secs), then switch off. Let stand for a few minutes to allow the oil to drain back to the sump. Now check dipstick, add oil as necessary.
drain the oil,
replace sump washer and torque plug up,
remove and replace filter,
fill engine with 4L or so of oil,
start engine, wait for oil light to extinquish,
let sit for a minute, check dip stick level.
top up until FULL.
the reason you start it after filling initially is because the oil filter is not full of oil initially until you start it and you will get a misleading oil level. (higher then it actually will be once new oil filter is full)
iv serviced cars many times... the way i see it and do it is,
get it warm (as warm oil will flow through internals easier than cold oil),
you get her up?,
undo plug and filter, let drain over a period of time (i leave it for over an hour, but no need to do it as long),
make sure area is clean of dirt ect. by using a rag, put new filter on 2/3 turn (run a bead of clear oil over rubber gasket helps seal under heat),
clean around plug hole on sump, put plug back in,
lower the car down,
put new oil in (i put in same amount that comes out), let sit for a bit, check dip stick and slowly top up bit by bit waiting about 1 min in between check until level is close to high level on dipstick,
take for a short drive to get oil a bit warm then recheck because new oil will be pushed around all internals, turbo ect. recheck and do slight top up done... and done right
* be sure to check your filter after car has been driven ( after a decent drive) for minor leakage. if leaking just tighten it a bit with your hand. (dont leave it to long to check and tighten as heat will make rubber gasket go hard and will break seal and then you will have to replace filter again...)
* best to do it yourself in your own time because most mechanics (under a time scedule) wont let it sit to drain long enough, which leaves contaminated oil inside engine and will contaminate new oil.
If done correctly when driving (highway or freeway) your dash cluster oil pressure gauge should be on the 4 mark or very very close to.
any qustions please ask... cheers
Edited by 4drftn
  • 6 months later...
Ive heard a few people commenting that you should fill your filter full of oil before fitting.
Please people, this will only end up in a mess, esspecially on a skyline where the filter is at an arms reach.
Do not waste your time, Ive never heard of a filter "popping off" because of this.
yeah i wouldn't worry, it only takes a couple of seconds to get pressure, because the engine was already hot from when you drained it, there still should be a fair bit of oil hanging around on most components, and if you run an oil like motul with ester or royal purple with molyb, it tends to cling to the parts for a while anyway after shutdown, so you have some protection still even without pressure.
And make sure that the old oil filter seal isnt stuck on the engine when you change the filter, really makes a mess of your fire wall and leaves a hansell and gretel trail from your mates house where you did it all the way back to your house and then leaves the rest of the oil in a ig puddle on your drive way...... errrr .... so im told :D
i put put abit of oil in and swish it around before installing. works for me. whether it does anything i dunno..ha
Dont bother putting any oil into the filter before installing it. It does nothing except make a mess. However, you do need to place grease or oil around the seal to help it stick. Also, when you drain say 4.9L of 5L of oil, 100mL in the engine wont make much difference. Plus, do you guys change your sump plug washer everytime you change your oil? Otherwise it will leak. If you know exactly how much oil goes into the car, pour it all in. Then run the car until the oil light goes out, wait another 10 seconds then turn the car off and check the oil. There is no need for huge drives, just enough to pump oil around the engine. If the oil mark in a few millimetres from the "Full" position on the dipstick, leave it. The oil will drain back into the sump and fill that up. While you are draining the oil, go though and check the underside of your car as well. Steering boots, oil leaks, CV boots, fuel filter, that sort of thing. Once you have gone through and checked all that, then the oil will have finished draining. Don't bother about waiting for every tiny drop to come out, there will always be some left in there. Dont worry about contaminated oil too much though, that is what an oil filter is there for!!
And finally, DO NOT FORGET TO TIGHTEN THE SUMP PLUG!!!! A hand tightend sump plug will not leak straigt away, but within a few kms it will fall out and its goodbye oil, goodbye motor, big, big trouble! That is the most important step of the whole procedure!
highway cruizing (100km/h in 5th or top) is the only way to check true oil pressure, oil pressure will not build up on idle. its not something you have to do straight away, but it gives you a good indication of the oil quality etc. currently in the car.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
