My turbo is back up for sale.
It is an R33 RB25 turbo highflowed by GCG. It comes with both the RB25 exhaust housing and a VG30 exhaust housing.
I had the VG30 housing machined and fitted to the turbo by GCG last year, I asked them to look over the turbo and they gave it the thumbs up.
I have owned this for approximately 18 months but it never made it onto a vehicle I own. Previous owner had receipts showing the turbo was highflowed only 3 months prior to me purchasing it.
Why is it back up for sale?
I sold it to a member of these forums, and being the nice guy that I am I gave him a warranty. He decided the turbo was defective and has returned it for a full refund.
Reason?
There is a small crack in the housing on the ring of the wastegate. It was taken to GCG by the purchaser and they called me to discuss.
As it is they said it wont affect performance, but may deteriorate over time. Given this the purchaser decided he did not want it.
He told me GCG offered to fix it for ~$120 if it would make him feel better, but he was not interested. (I assume they would weld it)
I now have the turbo again.
The deal!
I'm not a shop, so from now on there is no refund or warranty. If it was a brand new unused item I would be happy to oblige, BUT this is a second hand highflow built from a turbo that is ~10 years old. I will post pics of the VG30 crack tonight so there is no confusion. I will also post pics of the RB25 housing and a hairline crack (only visible on inside not outside) that also concerned the purchaser, but I believe to be normal in a housing of this age.
The pics
The wastegate crack
Rear wheel and housing
Compressor side and wheel
Pictures of both housings, you can see the size difference
Hairline crack on RB25 housing
OP6 goodness!
Turbo was sold for $1400, given all the f'ing around and the crack in the housing I'm letting it all go for SOLD pending full payment
https://www.sau.com.au/forums/topic/174921-gcg-hiflow-vg30rb25-hybrid/
hey,
wat sort of power did this turbo get.... wat is it rated hp wise.... is this better or equivalent to a garrett aftermarket unit such as GT3071R, 3076R, GT500- 500hp internal gated turbos. also is the entire unit ball bearing.
thanks
Hey johnabs,
Turbo info can be found here;
http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
I would anticipate 250 - 280 rwkws depending on your supporting hardware.
Lots of very nice offers on this turbo already!
PM sent.
By the way: Did you copy my Avatar? :thumbsup:
Just to let ppl know. I previously had a similar turbo on my car. It made 270rwkw@15psi, on a rb25 with Tomei cams and head porting. I sold it because i "thought" it was laggy, but after having similar response issues with a HKS GT-RS, i found that i had a restrictive exhaust. So this turbo combo has "similar" response to a GT-RS, but makes more power, at the same psi. The hi-flow is now fitted to a standard rb25NEO and is also making 270rwkw@16psi.
i believe thats what GCG tells us what to expect, but what did this particular turbo make in regards to power on ur car on wat psi and wat mods did u have. A mate had a gcg rb25 (not vg30 rear) and made 235rkw on 18psi or so, as they have very restrictive internal gates. do u have dyno papers to prove the power- do u need cams to rear the 250-270 mark.
Mate, the turbo never made it onto my car. So I have no graphs to prove the power to you...
There are alot of debates about how much power these and many other turbos make.
I cannot offer you a definitive response, although I can name many people with over 260kws using this turbo.
Hope the same avatar does not confuse you, so just look at the user name.
I also do not know Drew, but just have bought his cooler kit (Transfer of funds complete Drew :thumbsup: )
The internal gate does not restrict power :ninja:, whoever told you that has very little understanding of turbos. A small internal gate will only produce uncontrolled boost creep, because it can not expel gases fast enough thus the turbine spins faster, resulting in increased boost.
235rwkw on a std hi-flow, bolted to a std rb25 is about the limits of this turbo. With the bigger ext. housing, and all the supportive parts 280rwkw (my personal experience) would probably be the max of this turbo. Sometimes a turbo will max out at 16psi, sure an extra 2psi will get you an extra 5kw, but the gain per psi is reduced, thus not worth stressing the engine for 5kw. This is caused when the turbo's efficiency range has been passed, so the turbo creates too much heat, thus reducing the power gains.
Turbo back up for sale, read all about it in the first post.
If you plan to buy it...
Don't agree to a price on the phone and then bust my balls when you arrive at my house.
Don't ask for an unreasonable warranty on a second hand car part.
Do make sure you can afford the item you are buying.
If you want a brand new item with warranty, save up alot more money and buy a GTRS kit or the like.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
