Got my SAFC 2 installed and tuned along with a front mount and new fuel pump.
Tuned by Hitman (Matt) in Penrith.
Car made 217rwkw which was quite suprising, I was expecting more like 190 ish.
Matt seemed to think it was abnormally high as well and that my turbo might be abit of a freak. Either that or a happy dyno :( Either way, even if its actually making 50rwkw it still feels significantly quicker which is the main thing.
Running 11psi.
My only concern is the knock reading im seeing on the SAFC, Im thinking tomorrow im going to try re-set the SAFC's knock reading or something. Because it read like 250 at one point which just seems crazy high, however at no point did I hear anything even remotely like pinging nor did the car miss a beat.
A/F ratio seems safe enough, averaging 12:1
I would think that if it actually WAS pining that high I would have A: Heard it and B: Be crying over a dead engine right about now.
Reads around 10 or so on idle or just cruising so I dunno. I think ill call matt tomorrow and ask about it.
But yeah, pretty happy, Matt was very good to deal with and like I said, I can definetly notice the extra power, especially in 3rd.
https://www.sau.com.au/forums/topic/175356-safc-ii-in-and-tuned/
Nah, to be safe matt assumed it was the stock turbo and didn't bump it above 11psi. If it is the stocko theres no sense in risking it. Will be interesting if it is a highflow, previous owner never mentioned it.
More just wondering about that knock reading. I mean given my Air/Fuel ratio's and the fact that I could neither hear nor feel any sign of pinging, the reading of 250 would have to be wrong yeah? It didn't just read that once, read above 200 at one point and like 170 earlier on. Its possible that its just been calibrated wrong? Or a faulty knock sensor? Corect me if im wrong but I should get some sort of warning light on the dash at high knock levels yeah?
217 at 11 psi isn't a standard turbo. It makes that power at 14-15 psi.
most likely its a highflow. 217 at 11 psi sounds spot on for a highflow.
its either a high flow, or the dyno is happy by about 20rwkw.
Edited by The Mafia
Correct, if you have such a high knock count your engine warning light should come on. As for the knock count itself, hmmm seems interesting as that is a freaking high knock count for there to be no sign of damage. I would just reset the knock count to zero, take the car out for a slash (give it a bit up to redline) and see what the knock count is, if its not that high anymore than i wouldnt worry about it :)
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
