it can be done, you will need wider guards not just lipped, and a low offset wheel to clear. i just finished fitting up 19x10 all round on a gtt, 19offset with aftermarket guards, sits flush.
youll need a big tyre for 10", which on the front of a 4 door will make a fair difference when driving.
20x8.5front/20x10rear is btter suited in my opinion, unless you've already got the guards then go for it.
al
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3220674
20s is a big step from 19s believe it or not
you cant fit wide 20s and lower the car to a decent height with stock guards
you need wider guards or a shortened rear diff/suspension set up and big tubs
i can fit 19x10 all round on my car and it will look ok height wise
but anything wider than 20x8 and unless it sits like a land cruiser it wont fit
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3220834
how so?
20s on my car was the same as 18s ride and handling wise
I've got 20s and my car isn't a useless trophy, its a car i take out almost every weekend, my wife and kids love going out in it
not everyone is at home on a race track with vinyl graphics and massive GT wings from NASA
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3224549
  • 3 weeks later...
Unsprung Weight.
20 inch wheels are not your friend.
If the only reason to put this size wheel is for looks, you need to decide if this one 'pro' is worth the many 'cons' of a big heavy wheel.
Nice japanese light weight 17 or 18" Work, Volk etc wheels look 10 times better than ANY 20", full stop. Plus you get the extra respect and kudos. :laugh:
My two cents.
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3256446
I Can understand how it looks good on a 4 door but I dont understand why you would want 10" on the car all round? Id go 8.5 front (the steering would be shithouse with anything higher still takes me forever to spin the car) and 9.5 rears .. no chance you could fit 10" on the back from how much clearence I had :S
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3258209
Ive got 20x8.5 all round with 255/30 at the rear (which ends up being a touch under 10 inch), its slammed pretty hard with only lipped guards and doesnt rub at all at the rear, although does a occasionaly at the front when you are doing a u-turn.
Theres even room for 265s had I been available at the time.
https://www.sau.com.au/forums/topic/175415-20-x-10s/#findComment-3258904
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
