  • Replies 157
yeah got very packed at 7ish....got 2 runs in beofre 7 and the only had 2 more and left at 9.30 cause timing was playing up and i wanted to beat the rush...
got a new pb but left the slip in my brothers car so i can only go off memory....
60t
1.951
330
5.560
84.5mph
E/T
13.180
105mph
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3224891
the night was good....the track was exceptionally cold and even a decent burnout didnt help....absolutely no traction through 1st & 2nd.....pretty hairy as i hit second hard and the backs light up as usual but stayed light up and ass was all over the place. backed off and tried again and still light up so I just cruised for a 13.780
Next run track alot more heat so I bogged down off the line and ran a 13.3....next one it was rushed through burnout so bagged it up off the line....13.290
Final was best 60ft and was sort of a bog down but not much more i could have squeezed out of it.....found out that i didnt have boost as high as i thought and still hade my sub in my boot....might have been the difference from a 12 sec pass...
can anyone tell its been a while since i went to wsid....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3224895
Haha...
13.180 60ft was 1.951, which is my best so far...but boost was a little lower then i wanted...thought i raised it to 12psi but didnt save it...
yeah i remeber back when i was beating u.....now i got no chance.....
i gonna be pumped when i eventually hit the 12's....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225602
At least another PB Brendan what 60ft did you run for the 13.180?
I reckon the 12's is just around the corner
and yes you haven't been for a while did me running 12's first put you off? haha j/k :)
What did you run Ray?
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225650
I ran to the gym instead to lose some weight (further weight reduction),
IF THE WEATHER FORECAST is good i'll be going next week..
Last time it just shitted me when i got the car all ready even put the drag tyres on and called WSID at 5pm
(race meet for tonight has been cancelled) just my luck.
Either way Brendan at least everytime you get out there your setting a new PB :) keep up the good work
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225773
60t
1.951
330
5.560
84.5mph
E/T
13.180
105mph
hey man, i was the guy who talkd to ya when u finishd ur run!!
good stuff on the 13.1 i saw it from the grandstands
after seeing ur effort im deffintaly gonna get some slicks ay!!!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225970
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
